Topic: suggestions for Debounce on analog switches (Read 6848 times) previous topic - next topic
seanz2003
May 28, 2012, 07:57 pm Last Edit: May 28, 2012, 08:52 pm by seanz2003 Reason: 1
I am trying to come up with a debounce for an analog switch. So far, the program I have written seems to agree with my logic about 66% of the time. I want to think that the other 33% the time it is taking false readings from a loose breadboard and bad connections. Also, on occasion, it will continue to spit out zeros until I input a solid reading. In any case, I would appreciate some advise to improve this.
Code: [Select]
const int  buttonPin = A0;
int buttonstateCounter = 0;
int lastanalogvalue = 0;
int analogvalue = 0;
int difference;
long previousMillis = 0;
long interval = 1000;
 // initialize the button pin as a input:
 pinMode(buttonPin, INPUT);
 analogvalue = analogRead(buttonPin); // read the pushbutton input pin
 difference = abs(lastanalogvalue - analogvalue);
 if (difference > 5 ) { // button has either been pressed or released
     buttonstateCounter++;
     if (buttonstateCounter % 2 != 0)// button pressed, take value
      if(currentMillis - previousMillis > interval)
        Serial.println (analogvalue);
 lastanalogvalue = analogvalue;
and here is serial monitor output (anything less the ~160 is some sort of error):
804
980
694
172
0
0
11
12
178
382
587
980
14
586
177
382
James C4S
What do you mean by "analog switch"?
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
majenko
You really should think before creating your subject...
pYro_65
I agree, was posting the same thing, lol
Forum Mod anyone?
https://arduino.land/Moduino/
seanz2003
Yes, sorry about that. I must clarify... I should have said  that there are multiples switches connected to one analog pin through their own unique resistor. I am trying to use one analog pin to do different things. the rest of this program has already been posted multiple times on this forum so I didn't want people to get sick of seeing it. ("Oh, this guy again...")
The increments between button values  is approximately 150, though some are more than 200 because of the values of the resistors I had on hand.
James C4S
In that case, it appears you are leaving the pin floating when no button is pressed.  You should fix that with hardware, not software.
seanz2003
#6
May 28, 2012, 08:55 pm Last Edit: May 28, 2012, 09:22 pm by seanz2003 Reason: 1
Truly sorry, I did not mean to be offensive :/ does that happen with the titles very often? only with newbies right
seanz2003
and I should have stated that the analog pin has a 10K ohm pull down resistor. boy I am on a roll...
James C4S
You might want to draw up a schematic and post it.  Again, the behavior you describe suggests the pin is floating.
majenko
A circuit diagram would be nice.
This is how I do my analogue switches:
All the resistors have the same (10K) value.  I get:
All off - 1024
S1 on - 820
S2 on - 768
S3 on - 683
S4 on - 513
S5 on - 0
Combinations take the lowest value.
Then I average the results of my reading - depending on the program I am using that might just be do a number of reads and average them, or do a constant rolling average of the reads, using say 10 data points.
PeterH
If you want to debounce it then simplest general algorithm is to wait until it has provided consistent values for some period. You will have to decide how long that is - for example 0.1 seconds might be appropriate.
To implement that you would do your resistance comparisons to convert the input analog value to one of the switch positions, presumably held as an enum.
Your debounce algorithm takes a raw switch position as an input and produces a debounced switch position as the output.
It uses a state variable recording the input switch position at the last sample, and the time when the input switch position last changed, and the current debounced position.
Each time you read the analog value and convert it to a raw switch position, apply your debounce algorithm to it:
  • If the raw position is the same as the previous sample and the last change happened long enough ago, the debounced state changes to the new position.
  • If the current position is different to the previous position, record the new position and note the time when this change happened.
  • Record the raw position for next time.
  • Return the debounced position.
Note that the debounce algorithm treats the 'switch not pressed' state exactly the same as any other state - you have to take your hand off the switch long enough for your debounced state to change to 'not pressed' before you tell your application the switch has stopped being pressed.
You would put this debouncing code in front of the code discussed on your other thread which looks for changes in the debounced state.
seanz2003
How do i post an image? i see the button but how do i use it?
majenko
I'm not sure.  I host the images on my own web server and just paste in the URL inside [img] tags.
James C4S
Reply to this thread.  click "Additional Options..."  And then "Attach"
seanz2003
#14
May 28, 2012, 09:49 pm Last Edit: May 28, 2012, 10:39 pm by seanz2003 Reason: 1
ah it worked. I know this hardware set up works , i have used it with other examples without any issues with floating pins. for instance this code works very reliably:
Code: [Select]
const int sensorPin = A0;
const int ledPin = 9;
const int threshold1 = 50;   // an arbitrary threshold level that's in the range of the analog input
const int threshold2 = 200;
const int threshold3 = 400;
const int threshold4 = 540;
const int threshold5 = 640;
const int threshold6 = 740;
const int threshold7 = 900;
int sensorValue = 0;
const int sensorMin = 0;      // sensor minimum, discovered through experiment
const int sensorMax = 1023;
 // turn on LED to signal the start of the calibration period:
    pinMode(sensorPin, INPUT);
   sensorValue = analogRead(sensorPin);
   Serial.print(sensorValue);
   int range = map(sensorValue, sensorMin, sensorMax, 0, 9);
   switch (range) {
     case 0:    //
       Serial.println("0"); //0-102
     case 1:    // 54k ohm - 175
       Serial.println("r");
     case 2:    // 205-306
     case 3:    // 307-409 18.5k ohm 378
       Serial.println("c");
     case 4:    // 410-511
     case 5:    // 512-613 8.5k ohm 579
       Serial.println("e");
     case 6:    // 614-716 5.5k ohm 682
       Serial.println("s");
     case 7:    // 717-818 3k ohm 807
       Serial.println("f");
     case 8:    // 819-920 1.2k ohm 913
       Serial.println("ph adjust");
     case 9:    // 921-1023 0 ohm
       Serial.println("auto");
but nevertheless, it is a valid consideration. it could also be floating from bad connections.
