Topic: suggestions for Debounce on analog switches (Read 6402 times) previous topic - next topic
seanz2003
PeterH,
I appreciate your detailed explanation of debounce, but sadly my brain isn't processing it. could I trouble for a raw example of how the program might be set up, (If you have the time). I have tried adapting the arduino example but it returns two values for every press and I only want one.  I would also like it to only return a value once the button has been pressed
majenko
I have just started writing a handy "Average" library.
At the moment it just deals with rolling averages.  I have used it with this piece of analog button debounce code:
#include <Average.h>
#define SMOOTH 10
int history[SMOOTH];
int bvals[] = {1023,819,768,683,513,0};
int analogButton(int channel, int *vals, int nvals)
  int value;
  int lastValue = 0;
  int l;
  while(1)
    value = rollingAverage(history,SMOOTH,analogRead(channel));
    if(value == lastValue)
      for(l=0; l<nvals; l++)
        if(value == vals[l])
          return l;
    lastValue = value;
  int value;
  static int lastValue = 0;
  value = analogButton(0,bvals,6);
  while(lastValue == value)
  lastValue = value;
  Serial.println(value);
You will need my Average library for this: http://hacking.majenko.co.uk/libs/average
