Offline
Newbie
« Reply #2 on: May 29, 2012, 08:46:13 am » |
Thanks for your help.
Today ,I soldered the digital pin 7 on wifly shield. Following pin was already soldered. Vin Ground D7 D10 D11 D12 D13 but the Reset pin I didn't solder it yet, I would like to control Reset function directly from Arduino UNO. I connect Wifly shield and arduino uno together, and it communicate with my computer through USB cable. Now, the PIO 4 led and PIO6 led on the Wifly shield is blinking.
I upload Wifly_test example and open the Serial Monitor, but it still only display following string. ----- Starting WiFly Tester. Free memory:1166 -----
Should I modify some source code in the Wifly_test example ? or solder RST pin on wifly shield?
This is my Wifly_Test example code:
/* * WiFly_Device Test Platform * A simple tester for communicating with the WiFly GSx RN-131b/g series. * LGPL 2.0 * Tom Waldock, 2011 */
#include <Arduino.h> #include <Streaming.h> #include <SoftwareSerial.h> #include "WiFlySerial.h" #include "MemoryFree.h" #include "Credentials.h"
// Pins are 3 for INCOMING TO Arduino, 5 for OUTGOING TO Wifly // Arduino WiFly // 2 - receive TX (Send from Wifly, Receive to Arduino) // 3 - send RX (Send from Arduino, Receive to WiFly) WiFlySerial WiFly(2,3);
#define REQUEST_BUFFER_SIZE 120 #define HEADER_BUFFER_SIZE 150 #define BODY_BUFFER_SIZE 100
char bufRequest[REQUEST_BUFFER_SIZE]; char bufHeader[HEADER_BUFFER_SIZE]; char bufBody[BODY_BUFFER_SIZE];
void setup() { Serial.begin(9600); Serial.println(F("Starting WiFly Tester." ) ); Serial << F("Free memory:") << freeMemory() << endl;
WiFly.begin(); Serial << F("Starting WiFly...") << WiFly.getLibraryVersion(bufRequest, REQUEST_BUFFER_SIZE) << F(" Free memory:") << freeMemory() << endl; // get MAC Serial << F("MAC: ") << WiFly.getMAC(bufRequest, REQUEST_BUFFER_SIZE) << endl; // is connected ? // WiFly.setDebugChannel( (Print*) &Serial); WiFly.setAuthMode( WIFLY_AUTH_WPA2_PSK); WiFly.setJoinMode( WIFLY_JOIN_AUTO ); WiFly.setDHCPMode( WIFLY_DHCP_ON );
// if not connected restart link WiFly.getDeviceStatus(); if (! WiFly.isifUp() ) { Serial << "Leave:" << ssid << WiFly.leave() << endl; // join if (WiFly.setSSID(ssid) ) { Serial << "SSID Set :" << ssid << endl; } if (WiFly.setPassphrase(passphrase)) { Serial << "Passphrase Set :" << endl; } Serial << "Joining... :"<< ssid << endl;
if ( WiFly.join() ) { Serial << F("Joined ") << ssid << F(" successfully.") << endl; WiFly.setNTP( ntp_server ); // use your favorite NTP server } else { Serial << F("Join to ") << ssid << F(" failed.") << endl; } } // if not connected
Serial << F("IP: ") << WiFly.getIP(bufRequest, REQUEST_BUFFER_SIZE) << endl << F("Netmask: ") << WiFly.getNetMask(bufRequest, REQUEST_BUFFER_SIZE) << endl << F("Gateway: ") << WiFly.getGateway(bufRequest, REQUEST_BUFFER_SIZE) << endl << F("DNS: ") << WiFly.getDNS(bufRequest, REQUEST_BUFFER_SIZE) << endl << F("WiFly Sensors: ") << bufBody << WiFly.SendCommand("show q 0x177 ",">", bufBody, BODY_BUFFER_SIZE) << endl << F("WiFly Temp: ") << WiFly.SendCommand("show q t ",">", bufBody, BODY_BUFFER_SIZE) << F("WiFly battery: ") << WiFly.getBattery(bufBody, BODY_BUFFER_SIZE) << endl;
WiFly.SendCommand("set comm remote 0",">", bufBody, BODY_BUFFER_SIZE); memset (bufBody,'\0',BODY_BUFFER_SIZE);
WiFly.closeConnection(); Serial << F("After Setup mem:") << freeMemory() << endl ; Serial << F("WiFly now listening for commands. Type 'exit' to listen for wifi traffic. $$$ (no CR) for command-mode.") << endl;
// clear out prior requests. WiFly.flush(); while (WiFly.available() ) WiFly.read(); }
char chOut; void loop() { // Terminal routine
// Always display a response uninterrupted by typing // but note that this makes the terminal unresponsive // while a response is being received. while(WiFly.available() > 0) { Serial.write(WiFly.read()); } if(Serial.available()) { // Outgoing data WiFly.write( (chOut = Serial.read()) ); Serial.write (chOut); }
} //loop
