Loading...
Pages: [1]   Go Down
Author Topic: processing code?  (Read 1238 times)
Offline Offline
Newbie
View Profile
need help with processing code?I tried changing stuff around, tells me out of bound? changed ports around and still not processing right and i'm using port 4 can anyone see if it works on theirs? thanks for the help!
Code:
import processing.serial.*;
Serial myPort;
PFont myFont;
int j = 70;                   // counter
int inByte=0;
int wrote = 0;
void setup () {
  size(800, 600);        // window size
  frameRate(60);
  myFont = loadFont("ArialMT-12.vlw");
  textFont(myFont, 12);
  textAlign(LEFT);
  fill(#E9FF5B, 200);
  smooth();
  // set inital background:
  background(#000000, 200);
  println(Serial.list());
  myPort = new Serial(this, Serial.list()[2], 9600);
void draw()
 fill(0,1);
  rect(0,0, width, height);
  stroke(255);
  strokeWeight(1);
  line(70,550,800,550);
  line(70,38,70,550);
  textFont(myFont, 16);
  fill(#FFFFFF);
  text("0V", 32, 550 );
  text("1", 32, 447 );
  text("2", 32, 345 );
  text("3", 32, 242 );
  text("4", 32, 140 );
  text("5V", 32, 37 );
  for (int i=0; i<6;i++){
    line(63,550-(i*102.4),77,550-(i*102.4));
  stroke(230);
  strokeWeight(1);
    line(66,598.8-(i*102.4),74,598.8-(i*102.4));
  while (myPort.available() > 0) {
    inByte = myPort.read()*2;
   // if (inByte==254){
   //  incoming=myPort.read();
     // dev=myPort.read();
  stroke(#555FFF,200);
  fill(255);
   line(j, 550-inByte, j,550);
        // stroke(#55FF55,70);
   // fill(#FF555F);
  //ellipse(j, height/2 + dev, 2, 2);
  if (j > width) {
    j =70;
    background(#000000);
    fill(0,1);
  else {
    j++;
 if (wrote >20)
  fill(#FFFFFF);
  text(inByte/2, j,  (550- inByte)-30);
  wrote = 0;
  wrote++;
Logged
Offline Offline
Newbie
View Profile
The NIST withdrew the FIPS 55-3 database. This database included 5-digit numeric place codes for cities, towns, and villages, or other centers of population.
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
What?
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
@anthony8i - Can you post the port list from
Code:
Logged
Durham UK
Offline Offline
Full Member
aka Craig Turner
View Profile
WWW
 I have also not been able to get this to work
Code:
Try it wihout the [2].
If again no joy try this:
When I tried the same code on one of my projects a while ago, I had to use this instead:
Code:
Serial myPort;
  size(800, 800); // pane size
myPort = new Serial(this, "COMn", 9600);
wher "n" is the port number. Use whatever you are using for port eg 2.
Logged
Craig Turner, blog: http://gampageek.blogspot.co.uk/ It helps with my learning if I write things down, esp. for others to follow (constructive comments welcomed to improve)
Pages: [1]   Go Up
Print
Jump to:
