Pages: [1] 2   Go Down
Author Topic: warnings in 1.01 compile time  (Read 1193 times)
Under 1.0 ,
   the tone library reported a warning when compiling,
the 1.01 , seems to have added more warnings.
are these reported here ?
   are they fixed , or as 'just' warnings are they ignored ?
Miramar Beach, Florida
I just compiled the following example tone sketches on IDE v1.0.1 with no warnings or errors.
toneKeyboard
toneMelody
toneMultiple
tonePitchFollower
If you are using pre-v1.0 sketches on the newer releases (v1.0 or v1.0.1), you may need to modify that sketch code.
I hope the "dr" in your username means doctor. I have a pain right here. What should I do about it?
have you the verbose warnings turned on ?
I still have the following popping up in the verbose warning list.
C:\Program Files\Arduino\arduino-1.0.1\hardware\arduino\cores\arduino\Tone.cpp:93: warning: only initialized variables can be placed into program memory area
The Arduino libraries are pretty flakey - you have to compile them with all
warnings off.  To fix the "initialized variables" error, add:
// Re-define PROGMEM (http://gcc.gnu.org/bugzilla/show_bug.cgi?id=34734)
#undef PROGMEM
#define PROGMEM __attribute__((section(".progmem.data")))
to the top of Arduino.h.
I'm not sure if this caused by a new version of GCC, or just an old bug
recently exposed.  Anyhow, if you have doubts about where the strings
are actually going, check with avr-objdump.
Will
being new to arduino
   I'm an asic engineer,
      I'm sad that the libraries of a well established item like the arduino , are considered less than solid.
how do we get the fix's into the next release ?
File a report here. Having the fix included will speed up things.
http://code.google.com/p/arduino/
thank you
issue 963 raised !
I hope the warngings are fixed as its very off putting and over time  saps confidence in Arduino
Have faith! Every bug and fix I have filed has been fixed.  smiley
SF Bay Area (USA)
Strongly opinionated, but not official!
This one is actually a bug in the compiler.  Alas, one that ended up being "fixed" by having the compiler people declare that most of the avr-libc "pgmspace" implementation was "invalid."
oh dear
   a can of worms,
any chance the other warnings can be fixed ?
for this warning, could we initialise the variable like the warning asks ?
recently exposed.
I think it is an old bug exposed. My version of avr-gcc in my Ubuntu install shows 4.5.3 with Ubuntu patches. However, that is not the version that is used by the Arduino IDE. That is avr-gcc v4.3.2. Here is the thread that enlightened me:
http://arduino.cc/forum/index.php/topic,108211.0.html
I would try to help, but I will not waste my time on antique gcc versions.
appreciate your comment
what is  avr-gcc  might be a good question,
OK, I do know about gcc,
but did I not just install arduino on windows and I guess gcc came with it ,
  or did I have to install gcc seperatly ,
    does the team need to include a new gcc in the arduino distribution
        or do we need a way to upgrade gcc on windows machines.
and is this true of all the warnings that pop up in the compile windows  ?
I'm not a big Windoze fan, so that part I will presume. I think the Arduino crew is trying to get a stable version working on all operating systems. Can't blame them for that, but I think that version is a bit out of date.
WinAVR uses avr-gcc 4.3.2 and avr-libc v1.6.4. I believe that was a new release in 2008. Before upgrading (downgrading?) to IDE v1.0, I was using avr-gcc v4.5.3 and avr-libc v1.7.1 with IDE v0022. ??
As I understand, avr-gcc uses GCC with AVR code and the AVR library (avr-libc).
hi
won't get into the windows v linux v mac v what ever you want
thats like asking what is your fav editor !!!!
I always liked Vi and ed, but there you go,
   I now use a windows based editor,
so,
is avr-gcc 4.3.2 quite old then ?
   does the team up grade this or is it possible / practical for the user to do so ?
hay, I could always run a VM under windows to run Ubunto on,
    is that the way around the problem :->
I'm with you. I don't care what OS you prefer, and that is why I understand the Arduino crew's quest to get a standard IDE version working.
Those versions are about 4 years old if they used them to build WinAVR in 2008. What Arduino IDE version was current in 2008? What Arduino hardware was available then?
Pages: [1] 2   Go Up
