Topic: Led stay longer on without delay (Read 1 time) previous topic - next topic
napok
This is a working xbee project with two arduinos. (Receiver side)
One Led shows that they are in reach of each other.
The other one I can trigger by pushing a button on the other board.
But:
I want the ledPin (13) to be on as long as there is SoftwareSerial available.
Right now it is coming on and off too nervously. Usually I just would increase the delay.
But if I increase the delay, there is no or very delayed reaction of the other ButtonLed,
that I trigger from the other board.
I haven't quite understood how to implement the 'blink without delay',
because I don't want it to blink, it should stay on as long as the two boards
Could you help me to accomplish that?
Code: [Select]
#include <SoftwareSerial.h>
const int RXPin = 10;              // setting the pin to RX
const int TXPin = 11;              // setting the pin to TX
const int ButtonLed = 5;     // the number of the PushLed pin
const int ledPin =  13;      // the number of the LED pin
SoftwareSerial xbee (RXPin, TXPin);// defining the new serial name
  pinMode(ledPin, OUTPUT);
  pinMode(ButtonLed, OUTPUT);
  xbee.begin(9600);// set the data rate for the SoftwareSerial port
void loop() // run over and over
  if
  (xbee.available())
  digitalWrite(ledPin, HIGH);// set the LED on
  delay(200);               // wait for a second
  digitalWrite(ledPin, LOW);// set the LED on
  if
  (xbee.read() == 'L')
  digitalWrite(ButtonLed, HIGH);// set the LED on
  delay(500);               // wait for a second
  digitalWrite(ButtonLed, LOW);// set the LED on
CrossRoads
How long are you willing to wait before deciding to turn off the LED?
What you can do is note the time ( millis() ) every time you get a character and turn on an LED.
Then set a time when the LED is to be turned off.
Every pass thru loop, you check if the time has been reached, and if so you turn off the LED.
As long as characters keep coming in, the turn-off time will keep getting pushed out, and the LED will stay on.
I would do the time check as:
Code: [Select]
if ( (millis() -timeCheck)>=onDuration){
//turn off LED
digitalWrite(ButtonLed, LOW);// set the LED off
declare the time variable as 'unsigned long' data types.
That's the heart of blink-without-delay.
napok
napok
Hi again.
Got these errors:
xbee17receiver.cpp: In function 'void loop()':
xbee17receiver:31: error: 'timeCheck' was not declared in this scope
xbee17receiver:31: error: expected primary-expression before '>=' token
xbee17receiver:31: error: 'onDuration' was not declared in this scope
xbee17receiver:31: error: expected `;' before ')' token
Not sure how to implement your proposed code.
Please help! You have put the blink without delay part into the ButtonLed,
that is only supposed to come on after the other board owner has pressed a
button. I wanted to have the LedPin 13 on for longer that replies to the
xbee available part, when the two boards are near. So I put it into that part.
Of course once I've understood how to implement staying on without delay
I also want the ButtonLed to stay on a second without delay.
The code looks like this now:
Code: [Select]
  By Alexandra da Fonseca-Klein, Digital Jewellery project,
  For interactive Jewellery 'proximity sensing hearts'
  www.ADFK.co.uk; 2012
  2 Arduino Lilypad Simple Boards are connected via Xbee Series 2 radios.
  The Simple Board lacks Rx/Tx, therefore the use of SoftwareSerial.
  If the 2 wearers are within reach (30 feet approx) one LED
  comes on on the other wearers piece, if a button is pressed, another LED
  lights up. This is the receiver side.
#include <SoftwareSerial.h>        // use these specified set of commands
void setup()                // definitions that are always true
  if
  (xbee.available()) // check if there is actually data coming from
  {                  // communication port
  if  (millis() -timeCheck)>=onDuration)
  else                      //if not
  digitalWrite(ledPin, LOW);// turn the LED off
  if
  (xbee.read() == 'L')     // if you read the letter 'L'
  digitalWrite(ButtonLed, HIGH);// set the ButtonLED on
  delay(1000);               // wait for a second
  digitalWrite(ButtonLed, LOW);// turn the ButtonLED off
nickgammon
Can you stop cross-posting "Led stay longer on without delay" please? Locking this thread.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
