Loading...
Pages: [1]   Go Down
Author Topic: SD library mod for SPI_QUARTER_SPEED  (Read 549 times)
Offline Offline
Newbie
View Profile
Hello,
I don't know if anyone else faced this problem, but recent I came across an SD card that only works with SPI quarter speed... (had to use the QuickStart example of the SdFat library to figure that out).
I did not notice any method in the SD library to change the SPI speed. It can be achieved by a little modification in the library.
In SD.h file,  replace
Code:
boolean begin(uint8_t csPin = SD_CHIP_SELECT_PIN);
with
Code:
boolean begin(uint8_t csPin = SD_CHIP_SELECT_PIN, uint8_t spiSpeed = SPI_HALF_SPEED);
and in SD.cpp file,replace
Code:
boolean SDClass::begin(uint8_t csPin) {
    Performs the initialisation required by the sdfatlib library.
    Return true if initialization succeeds, false otherwise.
  return card.init(SPI_HALF_SPEED, csPin) &&
         volume.init(card) &&
         root.openRoot(volume);
with
Code:
boolean SDClass::begin(uint8_t csPin, uint8_t spiSpeed) {
  return card.init(spiSpeed, csPin) &&
After these modifications any of the following methods can be used to start the SD object.
Code:
SD.begin();
SD.begin(cspin);
SD.begin(cspin, spiSpeed);
spiSpeed (which is optional) can be SPI_FULL_SPEED, SPI_HALF_SPEED or SPI_QUARTER_SPEED as supported by SD2Card class.
Hope this helps.
« Last Edit: May 30, 2012, 06:02:34 pm by mcash » Logged
Pages: [1]   Go Up
Print
Jump to:
