Topic: 74HC595 and 7 segment display -> Control Library (Read 3586 times) previous topic - next topic
alhinde
May 31, 2012, 10:43 pm Last Edit: Jun 01, 2012, 07:05 pm by hikke Reason: 1
i wrote a library for control a 7-segment display(common cathode) with a 74HC595 ic.
Download -> Library
LINK -> Description, Pin connections
Code: [Select]
//Object initialisation
AH_74HC595(int SER_Pin, int RCLK_Pin, int SRCLK_Pin);
//Register functions
void setPin(int index, boolean value);
void setAll(boolean value);
void setValue(byte value);
void shift(boolean value);
void rotate();
// 7-Segment display functions
void showNumber(byte number);
void showSign(char sign);
void setPoint(boolean value);
samwell
Cool!
In case someone's got a common anode 7 segment LED display then there is sample code and a tutorial at:
http://lucidtronix.com/tutorials/41
Sparkfun has big 7segment common anode leds:
https://www.sparkfun.com/products/8546
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
