Pages: [1] 2   Go Down
Author Topic: MIDI synth - noise on serial reception?  (Read 937 times)
Nowhere
So I have a MIDI synth I'm working on, and it's all working nicely, except for one thing.
When the arduino receives any type of MIDI message (and I would assume any serial message in general), I get a small click on the audio output I have set up.  It's really not manageable, since doing things like turning a pitchbend wheel causes an audible buzz.
here's a little soundclip of the synth while I turn the mod and pitchbend wheel on my keyboard:
http://soundcloud.com/beefinator-2/arduino-synth-weirdness
About halfway through, I turn up the gain so the buzzing is more audible.  But the first half, that's at the same recording gain as when I play a couple notes, so you can see how relatively loud it is compared to the actual notes.
I'm using an MCP4822 DAC, but that's irrelevant, because I had this same issue a while ago when I used filtered PWM to generate an analog output.
I have in the program an interrupt routine that runs at 22KHz to update the DAC.
I would guess that the clicking has something to do with the serial reception interrupt, but I don't see how it would affect anything.  My routine is not reentrant, so it can't be that the serial interrupt is firing midway through my interrupt.  The DAC is completely updated by the time my routine is done, and the chip has an internal buffer, so the problem can't be the Serial interrupt slightly delaying my interrupt.
I looked through the Serial source code, the MIDI library code, and the atmega328 datasheet to try to figure out what's going on, but I couldn't find any solutions.  From what I understand, the SPI and USART are independent on the chip, so that's not an issue.
I dunno.
The sketch is attached; any ideas on something I'm missing?
Soundcloud page: http://soundcloud.com/beefinator-2
Youtube channel: http://www.youtube.com/user/beefinator14
Old soundcloud page (ran out of minutes): http://soundcloud.com/beefinator
Manchester (England England)
Solder is electric glue
My guess is that it is the serial ISR that is delaying the output sample ISR and causing the click.
Nowhere
Yes, I mentioned that in my post.  But I don't see how that could be the issue.
As I said above, the DAC has an internal buffer, so even if it is delayed, it should just remain at the same value for a tiny bit longer.  I don't believe that should cause any audible click, at least not nearly as loud as the one in the audio clip.
One more thought:  the loudness of the clicking changes depending on whether the Arduino is powered via USB or the DC jack.  So I think the problem could be the output very briefly going into a floating state, and then the clicking is just a short burst of noise.  That would change depending on how the circuit is grounded, etc.
But still, that doesn't make sense.  The only way the DAC chip will go into a floating state is if bit 4 of the high byte sent to the DAC is cleared.  Which, within my interrupt routine, I don't think it can be, since the high byte is always or'd with 0x70, or 0b01110000.
So I'm still puzzled.
Melbourne, Australia
Shannon Member
Lua rocks!
Bear with me if some of these things don't help ...
struct oscStruct  {
  volatile unsigned int increment;       //determines frequency.  see setFrequency().
  volatile unsigned int counter;         //keeps track of the phase.  the high byte gets us a sawtooth
  volatile byte dutyCycle;               //duty cycle of square wave.  but also holds config bits:
  //bits 0 and 1 of dutyCycle determine the waveform.
  //Notice that bit 1 decides triangle or not.  So if bit 1 is 1, bit 0 doesn't matter.
  //Bit 1:    0=saw or square,    1=triangle   |||||    Bit 0:    0=square     1=sawtooth
  volatile byte volume;                  //256 volume levels
oscStruct oscillators[8];                //8 oscillators
I would make the structure volatile, not sure if what you have will work perfectly:
struct oscStruct  {
volatile oscStruct oscillators[8];                //8 oscillators
What's all the assembler for? The natively-generated SPI is pretty fast. Example here:
http://www.gammon.com.au/forum/?id=11608
I output to a VGA screen which requires very precise timing. No assembler in it.
Nowhere
The SPI in assembler is just because I already was using assembler.
I was already using assembler because it was the most efficient way to do the oscillator calculations.  With 8 oscillators, I want it to be as fast as possible.  I got down to around 33 clock cycles for all the necessary code for one oscillator.  Each oscillator is individually configurable to be a triangle wave, sawtooth wave, or square wave (with ~64 different pulse widths), with an 8-bit volume envelope.  I think that's pretty good for 33 clock cycles!    smiley
I put both SPI transmits in between oscillator calculations so no extra time is used up transmitting.  And having the SPI also in assembly makes things faster; otherwise, 2 inline assembler functions would be needed, which would mean twice the pushing/popping of registers used.
Shannon Member
Lua rocks!
If you disconnect the serial input does the problem go away?
yeah, like nick said if you disconnect the serial input does the problem go away? if it's not the software then it's most probably the grounding. Audio and digital don't like sharing grounds. Also pcb layout is very critical for these types of applications. Try to separate the audio ground and digital ground and connect the together in only one spot as close to the power supply. Also decouple every chip with at least a 0.1uF cap. If all else fails think about using opto couplers to decouple the serial bus and/or a transformer on the audio output for galvanic isolation. there is a reason that midi outputs use opto couplers as standard.
greetings,
Thomas
Nowhere
Yep, now I think it's a grounding issue.
I'm using the Sparkfun MIDI breakout, and I realized it still makes the noise when the Rx pin is disconnected via the switch.
But that breakout does have an optoisolated input, so shouldn't it be fine?
It appears to be isolated, based on the schematic: http://www.sparkfun.com/datasheets/BreakoutBoards/BOB-09598-MIDI_Breakout-v11.pdf
Other info on my circuit:  the DAC's on a breadboard, connected to the Arduino just via 5v, gnd, clock, MOSI, and the slave select pin.  It is already decoupled.  The output of the DAC goes thru a 100uF cap to block DC, to the tip of the jack I'm using.  The sleeve of the jack is to the ground row on the breadboard, which is to the Arduino ground.
The grounding issue must be with the MIDI connection; it's fine as long as there's no MIDI input.  I even tried connecting a battery pack between the pins of the connector (obviously with the midi cable disconnected) and I get noise.
But it's theoretically isolated, so I don't know.
MIDI inputs are always opto isolated, it is part of the spec.
No it is as you point out optically isolated so there can't be a grounding problem.
Ring any bells?
When you do that you send a junk byte into the serial input.
Nowhere
I still think it's something related to grounding somehow.
If I remove the MIDI code and put in a Serial.begin(), then send stuff from the serial monitor in the IDE, no noise.
GRRRR...  I can unplug the arduino entirely except for the MIDI cable and the audio output cable.  And I still get the noise, but quieter.  Something must be wrong with the breakout?
Nowhere
I plugged the cable into the aux in on my laptop and recorded the noise into Audacity.  (don't have a proper oscilloscope...   smiley-razz )
Here are 2 of the clicks in the buzzing, normalized and with the space between them cut out (they're normally further apart)
could these be the MIDI messages bleeding through to the output somehow?  not sure how that would happen.
Shannon Member
Lua rocks!
The data pins are opto-isolated. There is a third pin (ground) which is supposed to be connected at one end but not the other. Maybe noise is bleeding into that?
Yes but it is supposed to be connected at the MIDI out end not the MIDI in end. There should be no connection to that on the receiver as it kind of defeats the point of having opto isolation.
Shannon Member
Lua rocks!
I mention it because perhaps it is in this case.
Nowhere
Nope.  I checked the schematic, and checked the actual board too, and no connection.
Pages: [1] 2   Go Up
