Pages: 1 [2]   Go Down
Author Topic: MIDI synth - noise on serial reception?  (Read 934 times)
Melbourne, Australia
Shannon Member
Lua rocks!
GRRRR...  I can unplug the arduino entirely except for the MIDI cable and the audio output cable.  And I still get the noise, but quieter.  Something must be wrong with the breakout?
With the MIDI cable disconnected is there any noise?
If it is connected but you don't connect the wire to the Rx pin of the board is there noise?
If you remove the serial reading (and the begin call) of the sketch is there noise?
If the MIDI device is powered down is there noise?
Nowhere
The noise is lots of short clicks, like in the screenshot of the waveform, one click I would assume for each MIDI message sent.  Turning the mod or pitchbend wheels sends a ton of messages, so the clicks turn into a buzz.  But there are also clicks at note on's and note off's.  So yes, no noise without a MIDI cable connected, but that's irrelevant, since the noise only happens when a MIDI message is sent.
I have the breakout board mounted as a shield, so I can't physically disconnect a wire.  But there is a switch that disconnects Rx, so the MIDI circuit doesn't interfere with programming the board.  And yes, the clicking/buzzing still happens with that switch disconnecting Rx.
Yep.  Assuming the DAC is already in active mode, i.e. not floating, I can upload the bare bones sketch with the empty setup and loop, and I still get the clicking/buzzing noise.  So absolutely an electrical issue.
Again, no, but not relevant, since the clicking only occurs when a message is sent.
I'm still puzzled...  I tried measuring the resistance between the MIDI connector pins and various points on the board, but nothing unusual.  It seems to be isolated.
Soundcloud page: http://soundcloud.com/beefinator-2
Youtube channel: http://www.youtube.com/user/beefinator14
Old soundcloud page (ran out of minutes): http://soundcloud.com/beefinator
Shannon Member
Lua rocks!
I think I would like to see a photo. The midi messages effectively are pulses at around 31250 KHz, so with a couple of 1 or 0 bits in a row you effectively have a square wave at 15625 Hz which would be audible, certainly.
You probably need to take steps to ensure that this digital "noise" (data, really) does not make it into your amp. So, shielded cable maybe. More decoupling caps on the DAC. If there is an amp, move it further away. Something like that.
Hi all,
I have a similar issue with one of my projects.  I'm using an Arduino to send midi messages to a Roland TD6v sound module, essentially forming a basic step sequencer.  In "free-running" mode (i.e. when the Arduino sketch provides its own timing/delays between steps, and no midi receive is used), the Arduino sends all of the right midi messages to the TD6v, and it sounds as expected.  In "ext-sync" mode however (I.e. when the Arduino receives tick, start, and stop information from the TD6v), I get the same sort of audio "buzz" that you do at the start of each note.
I should also add that the sound module's midi buffer fills up (which it should not!) a few seconds after playing, like the individual notes are triggered many times.  If I simplify the pattern to one hit per cycle, then I get the buzz but the midi buffer does not fill up.  I'm pretty sure that there's no way that the midi messages themselves could loop between the devices ("note chase" and midi "soft thru" are turned off on the TD6v), so I'm assuming that there is some sort of grounding issue or something else that I'm unaware of.  Perhaps there is some sort of power fluctuation, so the message appears to have been transmitted many times (pardon me if this sounds ridiculous… this is my first Arduino and midi project!).
I'm using the midi interface specified here (thanks to the author/designer!): http://www.stephenhobley.com/blog/2011/03/14/the-last-darned-midi-interface-ill-ever-build/
My next test will be to plug into a PC running some sort of midi message monitor so I can see what's happening on that front.
Any thoughts on this?
Thanks in advance to all.
Nowhere
So here's the circuit:
One thing I tried:  I replaced the 220Ω resistor labeled R2 in the sparkfun schematic with a 1KΩ resistor.
http://www.sparkfun.com/datasheets/BreakoutBoards/BOB-09598-MIDI_Breakout-v11.pdf
That value seems to be the correct value according to the optoisolator datasheet, not the MIDI hardware spec.  The noise is quieter with the larger resistor, but still audible.  I also tried a 10K, but not much of a noticeable difference from the 1K.
And jman, here's a good midi monitor if you don't already have one: http://www.snoize.com/MIDIMonitor/
« Last Edit: June 04, 2012, 11:39:25 am by sciguy » Logged
Thanks Sciguy.
It turns out that I'm a bit of a muppet, in that my "noise" was all software/sketch related.
I'm running the sketch on a mega which has multiple com ports.  I updated the sketch to use com1 for midi, so I could then use com0 for debug info (via serial monitor).  I then output everin min i/o event to the debug port for review...  which highlighted the issue almost immediately.
The sketch monitoring incoming midi "ticks" and updating two internal variables: currentTick and lastTick.  Elsewhere in the program, I was testing these two variables for a difference between them (as a crude form of event detection) and then triggering the corresponding midi "note on" command accordingly.  The trouble was that my SerialReceive() function was the only thing that updated the lastTick variable.  The Loop() function cycled many times between the ticks, and consequently the event was triggered multiple times, creating a brief buzz sound at the start of each note (doh!).  I changed the sketch to update the lastTick variable as soon as the current tick was processed (in addition to Serial.Receive) and all is now well and good smiley-grin
This explains why the midi buffer on my sound module got so full so quick!  Obvious in hindsight.  But unfortunately this does not help you with the noise issues that you have with your synth!  I almost feel bad now for poluting your thread with my problem smiley-wink
Best of luck with your synth.  Be sure to upload some samples when it nears completion!
Nowhere
I've already uploaded samples, the noise is only an issue when using pitchbend or control messages, or low velocity notes.  On notes with higher velocity, the click isn't noticeable.
Check out my soundcloud, link in my signature, for some samples, and also some songs I've made with the previous version of the synth.
Nowhere
So the noise has nothing to do with the DAC chip.  I put 2 10k resistors in a divider arrangement, giving 2.5v, the same as the output of the DAC when no notes are playing.  Then connected the output jack to the divider, bypassing the DAC, and I still get the noise with MIDI message reception.
I'm stuck...     smiley-confuse
Tomorrow I'll try making my own MIDI input circuit on a breadboard, to see if the sparkfun board's an issue.
Nowhere
Alright, so I fixed the problem!  There's ZERO audible noise of any sort now, even when I turn up the gain on my mizer to far past comfortable levels!
The solution I found on ladyada's page for the waveshield:
http://www.ladyada.net/make/waveshield/design.html
Turns out (and it makes sense) that you need a very low lowpass filter inputting the Vref pins on the DAC.  I had it originally connected directly to 5v, which was a very noisy power line.  E.g. the optoisolator was drawing current when MIDI messages were received, so the voltage fluctuated.
The waveshield uses a 15Hz cutoff filter; I got much better results with a 0.033Hz filter.   smiley-eek   It might take a second or two to ramp up to full voltage on startup of the synth, but I don't care, I have a little splash-screen anyway that appears.
Pages: 1 [2]   Go Up
