Topic: Using JSON library with Arduino (Read 1 time) previous topic - next topic
GUNASEELAN
In Arduino how to use both json generator and parser library in a single sketch ?
While i use ,
#include <JsonGenerator.h>
#include <JsonParser.h>
It throws errors stating,
"ArduinoJsonParser\utility\jsmn.cpp.o: In function `jsmn_parse(jsmn_parser*, char const*, jsmntok_t*, unsigned int)':
C:\Users\Guna Qruize\Documents\Arduino\libraries\ArduinoJsonParser\utility/jsmn.cpp:135: multiple definition of `jsmn_parse(jsmn_parser*, char const*, jsmntok_t*, unsigned int)'
ArduinoJson\JsonParser.cpp.o:C:\Users\Guna Qruize\Documents\Arduino\libraries\ArduinoJson\/JsonParser/jsmn.cpp:135: first defined here
ArduinoJsonParser\utility\jsmn.cpp.o: In function `jsmn_init(jsmn_parser*)':
C:\Users\Guna Qruize\Documents\Arduino\libraries\ArduinoJsonParser\utility/jsmn.cpp:250: multiple definition of `jsmn_init(jsmn_parser*)'
ArduinoJson\JsonParser.cpp.o:C:\Users\Guna Qruize\Documents\Arduino\libraries\ArduinoJson\/JsonParser/jsmn.cpp:250: first defined here"
rogerClark
I suspect the best source of answers will be the guy who wrote the code
Why don't you post an issue on GitHub (where I presume you got the code)
https://github.com/bblanchon/ArduinoJson
Or did you get it somewhere else?
Freelance developer and IT consultant
www.rogerclark.net
GUNASEELAN
Ya the same one ,
The creator has already explained this scenario, but i dint get it
http://blog.benoitblanchon.fr/arduino-json-v2-0/
Thanks,
Guna
rogerClark
It may help if you posted his response to this forum, and explain what you "didn't get"
www.rogerclark.net
nickgammon
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
