Loading...
Pages: [1]   Go Down
Author Topic: Using a variable file name?  (Read 803 times)
San Diego, CA
Offline Offline
Newbie
Arduino rocks
View Profile
I have 10 files on the SD card 1.txt 2.txt 3.txt on up to 10.txt…
I want to have a variable I can increment in a loop that will count up such as:
// set up the variable to be used
Int FileToOpen = 1;
myFile = SD.open(FileToOpen + ".txt");
// Do some reading of the file
Serial.println(myFile.read());
// increment the file number to be opend
FileToOpen++;
I get errors like cant use an int with a string/char and so on…
Any ideas of how to do this???
Thanks for any help!!!
shane
Logged
Denmark
Offline Offline
God Member
View Profile
WWW
I asked same question here:
http://arduino.cc/forum/index.php/topic,105997.0.html
As you se the solution was to use sprintf() something like
sprintf(newfile, "%0d.txt", FileToOpen); (your filenames should be 01.txt .. 10.txt)
« Last Edit: June 01, 2012, 01:24:53 pm by Erni » Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
This might help, it is a function taken from my MIDI wave shield sample player. It generates a file name with a number only it uses .wav in place of the .txt that you want.
It builds up the name in an char array which is then passed to the file opening routine.
Code:
        char toPlay[11];     //  string array for file to play 00.WAV to 99999.WAV
void makeName(int number, int depth){  // generates a file name 0.WAV to 9999.WAV suppressing leading zeros
  if(number > 9) {
    makeName(number / 10, ++depth); // recursion
    depth--;
    number = number % 10;   // only have to deal with the next significant digit of the number
  toPlay[indexToWrite] = (number & 0xf) | 0x30;
  indexToWrite++;
  if(depth > 0) {return; } // return if we have more levels of recursion to go
  else {  // finish off the string with the wave extesion
  toPlay[indexToWrite] = '.';
  toPlay[1+indexToWrite] = 'W';
  toPlay[2+indexToWrite] = 'A';
  toPlay[3+indexToWrite] = 'V';
  toPlay[4+indexToWrite] = '\0'; // terminator
  indexToWrite = 0; // reset pointer for next time we enter
Logged
Pages: [1]   Go Up
Print
Jump to:
