Topic: Flip-Flop from analog input? (Read 1 time) previous topic - next topic
confuzed
Hi I just got my arduino a week ago, and I'm having trouble with this.
Basically I want to create a laser tripwire (using a laser diode, and a Photoresistor),
and if the laser breaks, I want the state of a boolean to change, but when the laser comes back on, I want nothing to happen
Can anyone give me some example code for this flip flop effect?
Grumpy_Mike
You want to trigger stuff just on the falling (breaking) edge of the signal from the photo resistor?
If so do an analogue reading and compare it to some threshold to get a digital value. Remember the state of the switch when you last looked at it and compare it to what it is this time.
Only do your stuff if it is broken now and wasn't last time.
As the last thing in the loop transfer the current value to the remembered value.
AWOL
To save anyone wasting their time answering the same question in the sensors section, I've deleted it.
Do NOT cross post.
confuzed
Do NOT cross post.
Im really sorry, i won't do it again.
Can you give some example code on how to do this?
winner10920
You could part of it with hardware, and save yourself on the analog reads,
instead of a photoresistor(kinda slow) use an led with a comparator
have a potentiometer to adjust the trip level and the output will be a digital high or low, that will be much faster
in your code just have it once it goes low do something and set a flag to not do anything else
like
If(digitalRead(3)==1 && tripped ==0){
//do something
tripped=1;
//or replace digitalread with this for your setup
If(analogRead(A1) > 500 && tripped ==0){//etc and have the 500 number be watever is above abient but below the light
Now the need for speed would only be necessary if watever is tripping it is small and/or moving to fast for the photocell to respond, a quick google says anywhere between 2ms and 50ms response time
