Topic: BBEdit v10 and syntax highlighting (Read 3985 times) previous topic - next topic
hfp777
Jun 04, 2012, 12:27 am Last Edit: Jun 04, 2012, 04:54 pm by hfp777 Reason: 1
Hi all,
I would like to use BBEdit as a code editor.
However, I cannot find how to add Arduino syntax highlighting and completion (the reason why I wanted to use BBEdit in the first place...)
Has anyone ever pulled that off?
--edit: rephrase
PaulS
However, I cannot find how to add Processing syntax highlighting and completion
Are you in the habit of asking Arduino questions on the Processing forum, too? What exactly is your Arduino issue?
lloyddean
#2
Jun 04, 2012, 05:19 am Last Edit: Jun 04, 2012, 05:21 am by lloyddean Reason: 1
Depending upon your version of BBEdit the following should be used as a rough guide.
BBEdit->Preferences
Select "Languages" from the list on the left.
Click the '+' under the "Custom Extension Mappings" pane.
Select the "Suffix" side of the new entry and enter extension used by your version the Arduino IDE.
Click on the "Languages" side and select "C++" form the pop-up menu.
You should be good to go!
dxw00d
hfp777
Processing is the language Arduino is using, is it not?
hfp777
BBEdit->Preferences
Thanks but when doing this, instructions like pinMode, Serial.begin etc are not recognised and highlighted. This is very useful to read the code and this is what I am trying to accomplish in BBEdit.
dxw00d
No. The Arduino IDE is based on the Processing IDE. Processing (the language) is Java, the Arduino language is C/C++.
hfp777
My bad. So how to have BBEdit display Arduino's language like in the IDE where functions and libraries are highlighted?
James C4S
https://github.com/carlynorama/Arduino-BBEdit
hfp777
Yes I saw this before but there is no explanation whatsoever regarding how to install it?
James C4S
I guess I would install those files mentioned on page 360 of this document:
http://pine.barebones.com/manual/BBEdit_10_User_Manual.pdf
hfp777
Copying the .plist files to the directory mentioned in the doc doesn't cut it :(
dxw00d
I've just downloaded BBEdit, and the files from github. I created a Macintosh HD/Library/Application Support/BBEdit/Language Modules directory and copied the github files to it. Started BBEdit and opened a .pde file and the highlighting was working. As I use IDE 1.0, I changed the file suffix line to
        <key>BBLMLanguageSuffix</key>
        <string>.ino</string>
and it now works for ino files instead.
hfp777
Thanks, this method worked. I initially created the directory in my user folder not on the Macintosh HD
