Topic: Leonardo baud rate for USB CDC (Read 15306 times) previous topic - next topic
mkwired
It is best if you use code tags not quotes, it is the # next to the quote.
Why
Serial.flush();
I can't see it doing anything for you.
Because on the Uno, Serial.write is non-blocking.
Grumpy_Mike
Why
Because the box is smaller, it scrolls, and the forum doesn't scramble your code up so people can copy and paste the code and reproduce your problems.
And mainly because that is what people want around here and it show common decency to comply. After all you are the one asking the questions.
Only to the extent of not having a full buffer.
mkwired
Why
Quote within quote confusion... I didn't ask why.  I'm not trying to cause a problem.
True but not calling Serial.flush wouldn't show how fast bytes were being transferred out of the chip which was my goal.
Grumpy_Mike
Ok that last code as poster reports:-
39258 bytes/second
On a Leonardo.
mkwired
39258 bytes/second
On a Leonardo.
It seems like the rate is highly dependent on the computer where it wasn't on the Uno.
Grumpy_Mike
That is no surprise is it?
It is still a USB device and that get polled at a maximum of 1KHz, so I guess it is down to how fast the host computer empties the buffer. Allowing more bytes to be transferred.
mkwired
No.
Where does the 1kHz come from?
Grumpy_Mike
The polling rate of a USB HID device.
zeveland
That 1 ms polling rate is true only for HID (the keyboard and mouse) which use the USB interrupt transfer type.  CDC (which Leonardo refers to as Serial) uses the USB bulk transfer type which doesn't guarantee timing but does guarantee that it will transfer the data as fast as possible.  That "fast as possible" depends on what else is happening on the bus AND on the host computer.
In practice this does lead to different maximum transfer speeds for Serial on different computers (and even on the same computer under different workloads).  I don't have a board with me right now but, from memory, you can usually assume at least several tens of kb per second, up to a few hundreds of kbps.
It's not necessary to call Serial.begin() for the Leonardo since the CDC device is initialized elsewhere.  The stub was retained for backwards-compatibility.
Serial (which talks CDC over USB to the host) and Serial1 (which talks to pins 0 and 1 via the UART) are both definitely available and usable on the Leonardo.
mkwired
zeveland, I noticed much of the USB code for Arduino came from you.  Can you say how you learned to write "USB code?"  I read part of one book on the topic, but the material wasn't well written and as a result difficult to understand.
zeveland
mkwired, sorry - had overlooked your message.  I can't take much credit - most of the implementation was done by a brilliant guy named Peter Barrett.
Almost everything I know about USB has come from working with Dean Camera's LUFA project (http://fourwalledcubicle.com/LUFA.php), reading Jan Axelson's USB Complete book, and reading the specs until my eyes bled.
Daniel2
I found this interesting:
.. since it seems to say that the serial speed for the USB CDC is independent of whatever code you write. I'm inferring that since you don't need to open the port with a speed (e.g. Serial.begin(115200))
Does that sound right?
Which leads me to my second question:
Q: Is the serial monitor in the Arduino IDE monitoring the USB CDC serial port or the hardware serial port?
Thanks for any insights!
Daniel
pylon
It's the USB CDC (unless you connected a USB2Serial to the hardware serial port and to the PC too).
As you can see in the implementation:
void Serial_::begin(uint16_t baud_count)
... this is correct.
Daniel2
Thanks for the clarification!
The documentation on serial ports fir the Leonardo is a bit lacking.
When you open the serial monitor, and are monitoring the USB(CDC) connection, does the baud rate pulldown have any effect?
D
pylon
Theoretically yes, but it doesn't change any relevant parameter, it just sets some values in the driver on the PC. The counterpart on the Leonardo doesn't react on it.
