Topic: IRremote.h Library Help (Read 2091 times) previous topic - next topic
Manuel Silva
Hello all,
Please help on this problem.
I am using the <IRremote.h> library. I call the reading code as a function, the code I use is bellow. When I send an IR command at the first call of the function I receive the correct code, but, if I call again the function without send a IR command, I get again the same code, I need to call two more times the function to get a zero value.
Below  is the code I am using, and also the code I use to test the return command code.
Thanks in advance.
Manuel
Code: [Select]
uint16_t IR_code()
  key=0;
  if (irrecv.decode(&results)) // have we received an IR signal?
     //Serial.println(results.value, DEC); // Imprimir na porta serial o valor do controle
    //lcd.print(results.value, DEC); // Imprimir na porta serial o valor do controle
    switch(results.value)
    case 2107:key=10; break;//Menu
    case 2080:key=11; break;//Up
    case 2081:key=12; break;//Down
    case 2064:key=13; break;//right
    case 2065:key=14; break;//left
    case 2085:key=15; break;//enter
    case 2102:key=16; break;//exit
    case 2103:key=17; break;//stop
    case 2049:key=1; break;
    case 2050:key=2; break;
    case 2051:key=3; break;
    case 2052:key=4; break;
    case 2053:key=5; break;
    case 2054:key=6; break;
    case 2055:key=7; break;
    case 2056:key=8; break;
    case 2057:key=9; break;
    case 2048:key=0; break;
    default: key=100;
    return key;
  delay(2);
    irrecv.resume(); // receive the next value
  }  // Your loop can do other things while waiting for an IR command
Below is the code to test the return code.
Code: [Select]
void pano360()
   IR_code();
   key=0;
   uint8_t i=1;
   lcd.setCursor(0, 0);
   lcd.print("  Pano360 Mode  ");
   lcd.setCursor(0, 1);
   lcd.print("Num. Positions? ");
   lcd.setCursor(0,2);
   lcd.print("                ");
   while(i) // Get number of position till OK/enter(15) be pressed
       while (key==0)
       IR_code();
       Serial.print("test0 ");
       Serial.println(key, DEC);
       Serial.println("            ");
         lcd.setCursor(0,2);
         lcd.print(key,DEC);
         delay(3000);
       Serial.print("test1 = ");
       key=0;
      //i=0;
pylon
If you consumed a code with:
Code: [Select]
you should always call
Code: [Select]
irrecv.resume()
but you don't, you return the generated key.
BTW: you return the key value but you use the global variable for the value transfer. Either use a global variable in all cases or stick with local variables and return the value.
Manuel Silva
Pylon,
Thanks for your help. I am going to follow your advise.
Regards,
Manuel
