Topic: Boxes and buttons. (Read 1 time) previous topic - next topic
lost_and_confused
I know this is a silly question.  I admit it.
I am building a project and need some help.
This is a "new" version of something I have had for about 25 years.
The original box/case was an aluminium box and the buttons/switches were drilled in and there.
The new box is a plastic one and a completely different shape.
Alas now it is a bit too late to think "I should have done it differently".
The original box (top view) was nearly square.  The new one is more rectangular and it is oriented that I look at the narrower side/end.
The "front" is only just wide enough that the display fits left - right.
Also the Arduino and shield take up 90% of the height.
So there is scaresley any space on the front to put the switches/buttons.  Alas the 7 buttons of the shield would be handy, though only one is an absolute must - as I need to press something to turn off the alarm.
On top of that, I need some swithces to control the "mode" of what happens at the alarm time/s.
So I am kind of stuck to "how/where" I am going to put the switches, and what "kind".
Membrane type would be nice as they are low profile and don't need that many holes to be made.  They simply stick on.
florinc
Quote
What is the actual question? (I did not see any question marks.)
lost_and_confused
You are right.
I am stuck for ideas about the type of buttons to use.
Are these "membrane" buttons available for people like "me"?
I am also going to need help about getting the existing buttons on the PHI-2 shield to an external point so what ever I use, I have a simple point of interconnect.
I'm guessing I read the code and find the pins used by the buttons/assigned to the buttons and get something going from those pins to the connector.
I guess I am a bit stressed with where things are and the final parts to get the project working.
florinc
Here are the buttons:
http://www.seeedstudio.com/depot/sealed-membrane-3x4-button-pad-with-sticker-p-1044.html?cPath=156_160
If I were you, I would eliminate the buttons completely (because of the space limitations). I would remotely control the device through either infrared or bluetooth. You very probably already have a TV (or Apple TV) remote control already, and maybe even an Android phone with bluetooth.
Both IR and BT solutions cost about the same as the keypad solution you have in mind. Also, libraries for both are readily available.
lost_and_confused
Flornic,
Thanks.
The switch setup looks ok.
I shall investigate the remote idea, but at this stage it is only complicating something which shouldn't be that difficult.
It is only an alarm clock.  The 6/7 buttons on the sheild are "accademic" in that they won't be used in normal operations, though I will have to work out the ALARM CANCEL button.
I could make them all analogue and save myself 5 inputs.
I'll do a bit more looking and thinking.   I nearly have it working so if I can get it "limping along" it may suffice for now, but I would love to get it to full maturation at some stage.
majenko
Why not embed an accelerometer into the system.  Then you can cancel the alarm by hitting or shaking the alarm.  Be sure to anchor the rest of the components well ;)
florinc
Quote
Cost: at least $7 (for accelerometer) vs 10 cents (for the button).
majenko
Quote
Yes, but buttons are so passé.
lost_and_confused
Yeah, thanks.
Alas I may be attaching a temperature monitor so that kind of discounts that idea.
I was also thinking of connecting a GPS unit, but that has kind of gone to the dogs as it is too expensive for what I would get.
I also just learnt that "active" (mains) doesn't like to touch "earth".
Yeah, I knew this already, but was reminded of it last night.
Drats!
Docedison
There is also the thought that your clock is a person too a and using an accelerometer could leave evidence of your brutality behind in it's little memory   :smiley-roll-sweat:...
Doc
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
lost_and_confused
What I probably need then is a "pat detector" which detects me patting it - as in thanking it - and that turns the alarm off.
But seriously, I am stuck at what to do for getting all the required buttons/switches in/on the box.
6 for the clock alone - or at least one to "reset" the alarm, and then other ones to control what happens when the alarm goes off.
majenko
Quote
Capacitative sensing?
florinc
Quote
or a piezoelectric sensor
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
