Author Topic: [SOLVED] Arduino IDE 1.01 "An error occurred while starting the application."  (Read 5659 times)
Hi!
I have Win 7 x86, Arduino IDE 0023 is working great, but the last version has problem to open.
I see this error, and nothing happens. I have java 7 Rountime installed, but I think it doesn' matter because Arduino has his own java in folder.
Any suggestions?
« Last Edit: June 07, 2012, 12:24:29 pm by rekram » Logged
Austin, TX
Online Online
carpe diem
There has been some indication that a corrupt preferences.txt file can prevent the IDE from launching.
Try deleting your preferences.text file.
It can be found in the following location, depending on what version of Windows you have:
c:\Documents and Settings\<USERNAME>\Application Data\Arduino\preferences.txt (Windows XP)
c:\Users\<USERNAME>\AppData\Roaming\Arduino\preferences.txt (Windows Vista\Windows 7)
I removed but didn't help
Austin, TX
Online Online
carpe diem
Where do you have Arduino 1.0.1 installed?
For example, I have all of my versions of Arduino installed in these locations:
C:\arduino\arduino-1.0\
C:\arduino\arduino-1.0.1\
What is the error message your are seeing?
I have exactly the same problem. I just tried IDE 1.0 and it's working great. When I'm trying to run 1.0.1 after couple of seconds I'm getting this:
Launch4j
I've run "arduino.exe --l4j-debug" command, and the results are (seem to be fine):
CmdLine:   D:\arduino-1.0.1\arduino.exe --l4j-debug
WOW64:      yes
Working dir:   D:\arduino-1.0.1\.
Bundled JRE:   java
Check launcher:   D:\arduino-1.0.1\java\bin\javaw.exe (OK)
Add classpath:   lib\pde.jar
Add classpath:   lib\core.jar
Add classpath:   lib\jna.jar
Add classpath:   lib\ecj.jar
Add classpath:   lib\RXTXcomm.jar
Launcher:   D:\arduino-1.0.1\java\bin\javaw.exe
Launcher args:   -Xms128m -Xmx128m -classpath "lib;D:\arduino-1.0.1\java\lib\tools.jar;lib\pde.jar;lib\core.jar;lib\jna.jar;lib\ecj.jar;lib\RXTXcomm.jar" processing.app.Base
Args length:   156/32768 chars
IDE 1.0 works great from "D:\arduino-1.0"
Edit: Windows 7 Ultimate x64
I just tried to run 1.0.1 on second machine (but still Windows 7 x64) but I'm having the same error smiley-sad
« Last Edit: June 06, 2012, 01:14:34 am by szary » Logged
I found a walkaround on arduino IDE code.google site. Get the 1.0.1 RC2 IDE (http://files.arduino.cc/downloads/arduino-1.0.1-rc2-windows.zip) and replace lib/pde.jar from 1.0.1 with RC2 version. Works fine in my case.
Johannesburg UTC+2
I sometimes get that message with 101, sometimes not, which in itself is a bit of an issue- intermittent problems are notoriously tricky to deal with.
BUT, even when I do get the error message, it seems to start up and run fine anyway!
IT Crowd:
Roy... "Have you tried turning it off and on again?"
Moss.. "Have you tried forcing an unexpected reboot?"
Forum Administrator
Cambridge, MA
I think this is a problem with the Polish translation.  It included a translation of an internal string (used as a Date format); the translation makes the string invalid and there's an exception on startup.  You could try putting your computer into a language other than Polish or editing the editor.languages.current preference in your preferences.txt file (e.g. setting it to "en").
See: http://code.google.com/p/arduino/issues/detail?id=942
@mellis  big thanks for you and everyone who tried to help, setting
editor.languages.current=en
fixed the problem! smiley-grin
I have English version of Windows, but I use Polish keyboard and regional settings, probably that's why Arduino IDE try to set Polish language.
I added [SOLVED] to the topic name.
« Last Edit: June 07, 2012, 12:25:32 pm by rekram » Logged
Solution comming form http://rc-fpv.pl/viewtopic.php?p=105060
there is a problem with java engine initiation with languages/locales other than en/US
Solution is: create a.cmd file with one line:
java\bin\java -Duser.language=en -Duser.country=US -classpath "lib;lib\pde.jar;lib\core.jar;lib\jna.jar;lib\ecj.jar;lib\RXTXcomm.jar" processing.app.Base
and start Arduino by calling a.cmd - not arduino.exe
addded to Issues - ID# 952
