Topic: Keyboard Reprogram not working (Read 5357 times) previous topic - next topic
Markus_L811
Hello,
the Leonardo example Sketch did not write the right letters, I think it's the wrong keyboard layout or something is wrong, but I can't change it. I don't know what layout is used in the IDE files my layout is swiss-german and the reprogramm sketch is typing some very stange things.
Did someone has an solution?
BR.
Markus
pylon
The translation table (from ASCII characters to key codes) is in hardware/arduino/cores/arduino/HID.cpp. It's implemented only for the US keyboard but you're free to change it to your needs.
Markus_L811
#2
Jun 05, 2012, 06:18 pm Last Edit: Jun 05, 2012, 06:20 pm by Markus_L811 Reason: 1
Ah thanks for the hint, I looked at it
const uint8_t _asciimap[128] =...
is realy confusing i don't understand what is going on there, at the same time I looked at the keylayouts.c/.h from the teensy but I have no idea how to merge them useful. On the Teensy its allready done for many layouts. but I don't understand how the guy who wrote the HID.ccp and the USBAPI.h manage to send the key with the right ASCII-Value.
BR.
Markus
pylon
The ASCII values (index into the array _asciimap) are translated into key codes. A key code is a position on the keyboard. Most characters (a-z) are the same on the US and the Swiss keyboard, just Y and Z are swapped. If an ASCII value is entered on the keyboard by pressing it together with the shift key, the key code in the array is orred with the shift value. I guess you have the Swiss-German keyboard in front of you, so you should be able to fill the complete array with values for your mapping.
Markus_L811
Some clouds are gone, but i've looking at this paper www.usb.org/developers/devclass_docs/Hut1_12v2.pdf and some keys have different Usage ID like Key_return at USBAPI.h xB0 and in the paper x28 or Caps Lock xC1 and x39.
Strange at all
pylon
The translation table is not in USBAPI.h but in HID.cpp and there the character line feed (10) is translated into 0x28.
The definitions you found are especially for this code and are translated in the press method:
Code: [Select]
if (k >= 136) { // it's a non-printing key (not a modifier)
k = k - 136;
} else if (k >= 128) { // it's a modifier key
_keyReport.modifiers |= (1<<(k-128));
k = 0;
} else { // it's a printing key
k = pgm_read_byte(_asciimap + k);
0xB0 - 136 = 0x28
so this makes sense.
Edit: corrected LF code.
Markus_L811
Code: [Select]
k = k - 136;
k = 0;
0xB0 - 136 = 0x28
Hmmm.
I changed some key but nothing happend, the IDE recompilied it i think, tested for sure slashed some keys out and i get some errors
pylon
Can you get a bit more specific? Show us your code and the output you get (including the errors).
Markus_L811
There it comes:
Some define parts are double from the USBAPI.h I merged some parts from the keylayouts.h for better testing, if I uncomment some lines I get an not declared message.
Insert in the HID.ccp at line 281
Part1
Code: [Select]
#define SHIFT     0x80
#define ASCII_00 0x00             // NUL
#define ASCII_01 0x00             // SOH
#define ASCII_02 0x00             // STX
#define ASCII_03 0x00             // ETX
#define ASCII_04 0x00             // EOT
#define ASCII_05 0x00             // ENQ
#define ASCII_06 0x00             // ACK
#define ASCII_07 0x00             // BEL
#define ASCII_08 0x2a         // BS Backspace
#define ASCII_09 0x2b         // TAB Tab
#define ASCII_0A 0x28         // LF Enter
#define ASCII_0B 0x00             // VT
#define ASCII_0C 0x00             // FF
#define ASCII_0D 0x00             // CR
#define ASCII_0E 0x00             // SO
#define ASCII_0F 0x00             // SI
#define ASCII_10 0x00             // DEL
#define ASCII_11 0x00             // DC1
#define ASCII_12 0x00             // DC2
#define ASCII_13 0x00             // DC3
#define ASCII_14 0x00             // DC4
#define ASCII_15 0x00             // NAK
#define ASCII_16 0x00             // SYN
#define ASCII_17 0x00             // ETB
#define ASCII_18 0x00             // CAN
#define ASCII_19 0x00             // EM
#define ASCII_1A 0x00             // SUB
#define ASCII_1B 0x00             // ESC
#define ASCII_1C 0x00             // FS
#define ASCII_1D 0x00             // GS
#define ASCII_1E 0x00             // RS
#define ASCII_1F 0x00             // US
#define KEY_LEFT_CTRL         0x80
#define KEY_LEFT_SHIFT         0x81
#define KEY_LEFT_ALT           0x82
#define KEY_LEFT_GUI         0x83
#define KEY_RIGHT_CTRL       0x84
#define KEY_RIGHT_SHIFT       0x85
#define KEY_RIGHT_ALT         0x86
#define KEY_RIGHT_GUI         0x87
#define KEY_A                    0x04
#define KEY_B                    0x05
#define KEY_C                    0x06
#define KEY_D                    0x07
#define KEY_E                    0x08
#define KEY_F                    0x09
#define KEY_G                    0x0A
#define KEY_H                    0x0B
#define KEY_I                    0x0C
#define KEY_J                    0x0D
#define KEY_K                    0x0E
#define KEY_L                    0x0F
#define KEY_M                    0x10
#define KEY_N                    0x11
#define KEY_O                    0x12
#define KEY_P                    0x13
#define KEY_Q                    0x14
#define KEY_R                    0x15
#define KEY_S                    0x16
#define KEY_T                    0x17
#define KEY_U                    0x18
#define KEY_V                    0x19
#define KEY_W                    0x1A
#define KEY_X                    0x1B
//#define KEY_Y                    0x1C
#define KEY_Y                    0x04
//#define KEY_Z                    0x1D
#define KEY_Z                    0x04
#define KEY_1                    0x1E
#define KEY_2                    0x1F
#define KEY_3                    0x20
#define KEY_4                    0x21
#define KEY_5                    0x22
#define KEY_6                    0x23
#define KEY_7                    0x24
#define KEY_8                    0x25
#define KEY_9                    0x26
#define KEY_0                    0x27
#define KEY_RETURN               0xB0
#define KEY_ESC                  0xB1
#define KEY_BACKSPACE            0xB2
#define KEY_TAB                  0xB3
#define KEY_SPACE                0x2C
#define KEY_MINUS                0x2D
#define KEY_EQUAL                0x2E
#define KEY_LEFT_BRACE           0x2F
#define KEY_RIGHT_BRACE          0x30
#define KEY_BACKSLASH            0x31
//#define KEY_NON_US_NUM  50
#define KEY_SEMICOLON            0x33
#define KEY_QUOTE                0x34
#define KEY_TILDE                0x35
#define KEY_COMMA                0x36
#define KEY_PERIOD               0x37
#define KEY_SLASH                0x38
#define KEY_CAPS_LOCK            0xC1
#define KEY_F1           0xC2
#define KEY_F2           0xC3
#define KEY_F3           0xC4
#define KEY_F4           0xC5
#define KEY_F5           0xC6
#define KEY_F6           0xC7
#define KEY_F7           0xC8
#define KEY_F8           0xC9
#define KEY_F9           0xCA
#define KEY_F10           0xCB
#define KEY_F11           0xCC
#define KEY_F12           0xCD
//#define KEY_PRINTSCREEN 70
//#define KEY_SCROLL_LOCK 71
//#define KEY_PAUSE       72
#define KEY_INSERT               0xD1
#define KEY_HOME                 0xD2
#define KEY_PAGE_UP              0xD3
#define KEY_DELETE               0xD1
#define KEY_END                  0xD5
#define KEY_PAGE_DOWN            0xD6
#define KEY_RIGHT_ARROW          0xD7
#define KEY_LEFT_ARROW           0xD8
#define KEY_DOWN_ARROW           0xD9
#define KEY_UP_ARROW             0xDA
#define ASCII_20 KEY_SPACE // 32
#define ASCII_21 KEY_1 | SHIFT // 33 !
#define ASCII_22 KEY_2 | SHIFT // 34 "
#define ASCII_23 KEY_3 | SHIFT // 35 # ??
#define ASCII_24 KEY_4 | SHIFT // 36 $
#define ASCII_25 KEY_5 | SHIFT // 37 %
#define ASCII_26 KEY_7 | SHIFT // 38 &
#define ASCII_27 KEY_QUOTE       // 39 '
#define ASCII_28 KEY_9 | SHIFT // 40 (
#define ASCII_29 KEY_0 | SHIFT // 41 )
#define ASCII_2A KEY_8 | SHIFT // 42 *
#define ASCII_2B KEY_EQUAL | SHIFT // 43 +
#define ASCII_2C KEY_COMMA // 44 ,
#define ASCII_2D KEY_MINUS // 45 -
#define ASCII_2E KEY_PERIOD // 46 .
#define ASCII_2F KEY_SLASH   // 47 /
#define ASCII_30 KEY_0 // 48 0
#define ASCII_31 KEY_1 // 49 1
#define ASCII_32 KEY_2 // 50 2
#define ASCII_33 KEY_3 // 51 3
#define ASCII_34 KEY_4 // 52 4
#define ASCII_35 KEY_5 // 53 5
#define ASCII_36 KEY_6 // 54 6
#define ASCII_37 KEY_7 // 55 7
#define ASCII_38 KEY_8 // 55 8
#define ASCII_39 KEY_9 // 57 9
#define ASCII_3A KEY_SEMICOLON | SHIFT // 58 :
#define ASCII_3B KEY_SEMICOLON // 59 ;
#define ASCII_3C KEY_COMMA // 60 <
#define ASCII_3D KEY_EQUAL // 61 =
#define ASCII_3E KEY_PERIOD | SHIFT // 62 >
#define ASCII_3F KEY_SLASH | SHIFT // 63 ?
#define ASCII_40 KEY_2 | SHIFT // 64 @
#define ASCII_41 KEY_A | SHIFT // 65 A
#define ASCII_42 KEY_B | SHIFT // 66 B
#define ASCII_43 KEY_C | SHIFT // 67 C
#define ASCII_44 KEY_D | SHIFT // 68 D
#define ASCII_45 KEY_E | SHIFT // 69 E
#define ASCII_46 KEY_F | SHIFT // 70 F
#define ASCII_47 KEY_G | SHIFT // 71 G
#define ASCII_48 KEY_H | SHIFT // 72 H
#define ASCII_49 KEY_I | SHIFT // 73 I
#define ASCII_4A KEY_J | SHIFT // 74 J
#define ASCII_4B KEY_K | SHIFT // 75 K
#define ASCII_4C KEY_L | SHIFT // 76 L
#define ASCII_4D KEY_M | SHIFT // 77 M
#define ASCII_4E KEY_N | SHIFT // 78 N
#define ASCII_4F KEY_O | SHIFT // 79 O
#define ASCII_50 KEY_P | SHIFT // 80 P
#define ASCII_51 KEY_Q | SHIFT // 81 Q
#define ASCII_52 KEY_R | SHIFT // 82 R
#define ASCII_53 KEY_S | SHIFT // 83 S
#define ASCII_54 KEY_T | SHIFT // 84 T
#define ASCII_55 KEY_U | SHIFT // 85 U
#define ASCII_56 KEY_V | SHIFT // 86 V
#define ASCII_57 KEY_W | SHIFT // 87 W
#define ASCII_58 KEY_X | SHIFT // 88 X
#define ASCII_59 KEY_Y | SHIFT // 89 Y
#define ASCII_5A KEY_Z | SHIFT // 90 Z
#define ASCII_5B KEY_LEFT_BRACE // 91 [
#define ASCII_5C KEY_BACKSLASH // 92
#define ASCII_5D KEY_RIGHT_BRACE // 93 ]
#define ASCII_5E KEY_0 | SHIFT // 94 ^
#define ASCII_5F KEY_MINUS | SHIFT // 95 _
#define ASCII_60 KEY_TILDE // 96 `
#define ASCII_61 KEY_A // 97 a
#define ASCII_62 KEY_B // 98 b
#define ASCII_63 KEY_C // 99 c
#define ASCII_64 KEY_D // 100 d
#define ASCII_65 KEY_E // 101 e
#define ASCII_66 KEY_F // 102 f
#define ASCII_67 KEY_G // 103 g
#define ASCII_68 KEY_H // 104 h
#define ASCII_69 KEY_I // 105 i
#define ASCII_6A KEY_J // 106 j
#define ASCII_6B KEY_K // 107 k
#define ASCII_6C KEY_L // 108 l
#define ASCII_6D KEY_M // 109 m
#define ASCII_6E KEY_N // 110 n
#define ASCII_6F KEY_O // 111 o
#define ASCII_70 KEY_P // 112 p
#define ASCII_71 KEY_Q // 113 q
#define ASCII_72 KEY_R // 114 r
#define ASCII_73 KEY_S // 115 s
#define ASCII_74 KEY_T // 116 t
#define ASCII_75 KEY_U // 117 u
#define ASCII_76 KEY_V // 118 v
#define ASCII_77 KEY_W // 119 w
#define ASCII_78 KEY_X // 120 x
#define ASCII_79 KEY_Y // 121 y
#define ASCII_7A KEY_Z // 122 z
#define ASCII_7B KEY_LEFT_BRACE | SHIFT // 123 {
#define ASCII_7C KEY_BACKSLASH | SHIFT // 124 |
#define ASCII_7D KEY_RIGHT_BRACE | SHIFT // 125 }
#define ASCII_7E KEY_TILDE | SHIFT // 126 ~
#define ASCII_7F KEY_BACKSPACE // 127
Markus_L811
Part 2
Code: [Select]
extern
const uint8_t _asciimap[128] PROGMEM;
const uint8_t _asciimap[128] = {
        ASCII_00, ASCII_01, ASCII_02, ASCII_03,
        ASCII_04, ASCII_05, ASCII_06, ASCII_07,
        ASCII_08, ASCII_09, ASCII_0A, ASCII_0B,
        ASCII_0C, ASCII_0D, ASCII_0E, ASCII_0F,
        ASCII_10, ASCII_11, ASCII_12, ASCII_13,
        ASCII_14, ASCII_15, ASCII_16, ASCII_17,
        ASCII_18, ASCII_19, ASCII_1A, ASCII_1B,
        ASCII_1C, ASCII_1D, ASCII_1E, ASCII_1F,
        ASCII_20, ASCII_21, ASCII_22, ASCII_23,
        ASCII_24, ASCII_25, ASCII_26, ASCII_27,
        ASCII_28, ASCII_29, ASCII_2A, ASCII_2B,
        ASCII_2C, ASCII_2D, ASCII_2E, ASCII_2F,
        ASCII_30, ASCII_31, ASCII_32, ASCII_33,
        ASCII_34, ASCII_35, ASCII_36, ASCII_37,
        ASCII_38, ASCII_39, ASCII_3A, ASCII_3B,
        ASCII_3C, ASCII_3D, ASCII_3E, ASCII_3F,
        ASCII_40, ASCII_41, ASCII_42, ASCII_43,
        ASCII_44, ASCII_45, ASCII_46, ASCII_47,
        ASCII_48, ASCII_49, ASCII_4A, ASCII_4B,
        ASCII_4C, ASCII_4D, ASCII_4E, ASCII_4F,
        ASCII_50, ASCII_51, ASCII_52, ASCII_53,
        ASCII_54, ASCII_55, ASCII_56, ASCII_57,
        ASCII_58, ASCII_59, ASCII_5A, ASCII_5B,
        ASCII_5C, ASCII_5D, ASCII_5E, ASCII_5F,
        ASCII_60, ASCII_61, ASCII_62, ASCII_63,
        ASCII_64, ASCII_65, ASCII_66, ASCII_67,
        ASCII_68, ASCII_69, ASCII_6A, ASCII_6B,
        ASCII_6C, ASCII_6D, ASCII_6E, ASCII_6F,
        ASCII_70, ASCII_71, ASCII_72, ASCII_73,
        ASCII_74, ASCII_75, ASCII_76, ASCII_77,
        ASCII_78, ASCII_79, ASCII_7A, ASCII_7B,
        ASCII_7C, ASCII_7D, ASCII_7E, ASCII_7F
pylon
And what do you get? Show us the code your trying with and what the output on the PC is.
Markus_L811
For single test I use the Keyboardserial
Code: [Select]
  // open the serial port:
  // initialize control over the keyboard:
  Keyboard.begin();
  // check for incoming serial data:
  if (Serial.available() > 0) {
    // read incoming serial data:
    char inChar = Serial.read();
    // Type the next ASCII value from what you received:
    Keyboard.write(inChar);
I send an Z and get an Y
Markus_L811
How can I forced an recompile of the lib's? on the IDE 1.0.1
pylon
Why are you sending key code 0x04 for a 'Z' and for a 'Y'? Do you really try with the code you posted? Keep in mind that the Swiss keyboard swaps the two keys, so you must send 0x1d for a 'Y' and 0x1c for a 'Z'.
Markus_L811
Yes I tryed to see if it works, I have also swapped the define to change the send ID
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
