Topic: Seeeduino stalker (Read 3348 times) previous topic - next topic
edwardhensel
the Seeeduino Stalker has got to be a perfect board but the only problem is that the I/O ports run on 3.3v  I need them to run on 5.5v.  Below you will find a link to the wiki on the Stalker, with schematics.  What can I remove on the board it self to make it run on 5v.  I see on the schematic that 5v is coming in but by the time it his the microprocessor it is 3.3v.
http://www.seeedstudio.com/wiki/Seeeduino_Stalker_v2.2
Also does any one know of an arduino compatible board that has similar features that the Stalker has?
dpharris
I have not, yet, gone down this road.  However, a UNO compatible with these features would be nice.  Should be a little cheaper, too!
David
Dr. David Harris
OpenLCB Dev Team
CrossRoads
What parts of it do you need?
A lot of the devices on the board are 3.3V only - the SD socket, the XBee socket, etc.
What portions do you need?
My Bobuino board has 5V IO, DS1307 battery backed clock, RS232, shield headers, extra IO, with seperate 3.3V regulator & level-translated signals for the an SD card.
But if you need the battery charger, it doesn't do that.
So what features do you need?
CrossRoads
So if the board was redesigned to boost the LiPo battery output to 5V so the uC could run at 5V that'd be what is needed?
And keep 3.3V for the Xbee socket and SD and uSD card socket?
Would you add USB interface too, vs pins only for an offboard USB/Serial adapter?
That wouldn't be that difficult to arrange.
I'd boost the processor to a '1284P too for its 16K SRAM.
edwardhensel
the arduino comparable sockets run on 3.3v and I need them to run on 5v.  That is the problem with this board.
florinc
What shield do you want to use with seeeduino stalker?
CrossRoads
So you want the same board, with say a TXB0104/TXB0106 between the uC and the 3.3V devices,
and the uC and shield headers to run from5V otherwise.
Does it need to be 5V, or just whatever voltage the LiPo is at? As the uC will be happy running at 16 MHz down to about 3.8V, the low end of what a LiPo can do.
Chagrin
Like florinc asked, what 5V device are you wanting to use with it? More than likely the problem you think you're going to have doesn't exist.
edwardhensel
Things like ultrasonic censors, PIR Motion, lazors  stuff like that
florinc
Ultrasonic sensor working at 3V3:
http://www.sparkfun.com/products/639
Motion sensor working at 3V3:
http://www.sparkfun.com/products/9587
and so on.
edwardhensel
The only problem is that both of those sensor go a lot farther with 5.5v.  So there range is dependent on the voltage that they run on.   I would like to the the extra distance.
cantore
If you look at stalker version 2.2 it is written it has a 4 ping groove header that can run at 3.3 or 5v. Knowing seeedstudio I suppose that this port is only power supplied at 5v but the digital pin and the ADC are supposed to work only in the 0->3.3v  range
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
