Global Moderator
Dallas
Online
Shannon Member
« Reply #30 on: June 10, 2012, 01:11:50 am » |
not too sure what exactly needs to be modified to make the ArduinoISP sketch work. I'll look through it. I've attached a modified version of ArduinoISP.ino that I think will work. Please report back if it does work. (and, of course, if it does not work) Should I just buy an AVR ISP to program the attiny's? A dedicated programmer is certainly a handy thing but I believe you are, in the worst case, just a few lines of code away from something that will work.
Logged
SE USA
Offline
Faraday Member
@ssh0le
« Reply #31 on: June 10, 2012, 01:16:02 am » |
I just use the .22 version
I wish someone could come up with a decent list of advantages of 1.0 other than the obvious broken libraries, broken examples, larger compiled code and just general jankyness
Logged
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
Offline
Jr. Member
« Reply #32 on: June 10, 2012, 12:10:51 pm » |
Ok, so I uploaded the new ArduinoISP sketch to the arduino. Then I inserted the capacitor to disable reset. Opened the Blink Sketch and changed the 13's to 0's. double-checked the wiring to the attiny. chose board: 'ATtiny85 @ 8 MHz (internal oscillator; BOD disabled)' and the Programmer was 'Arduino as ISP' Uploaded successful! but the LED on pin 5 from the attiny does not blink. I tried several LED's w/ and w/out a resistor and there is no blink. Even tried a different attiny85 to make sure mine wasn't damaged for some reason. what could be causing this? This is the sketch that I uploaded, as well as the Verbose Output: /* Blink Turns on an LED on for one second, then off for one second, repeatedly. This example code is in the public domain. */
void setup() { // initialize the digital pin as an output. // Pin 13 has an LED connected on most Arduino boards: pinMode(0, OUTPUT); }
void loop() { digitalWrite(0, HIGH); // set the LED on delay(1000); // wait for a second digitalWrite(0, LOW); // set the LED off delay(1000); // wait for a second }
Binary sketch size: 748 bytes (of a 8192 byte maximum) /Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -pattiny85 -cstk500v1 -P/dev/tty.usbmodemfa141 -b19200 -Uflash:w:/var/folders/qk/qkj6-lNJEq8p-Fz5jk0-1U+++TI/-Tmp-/build8636959170477628617.tmp/Blink.cpp.hex:i
avrdude: Version 5.11, compiled on Sep 2 2011 at 18:52:52 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf" User configuration file is "/Users/Darcyneal/.avrduderc" User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/tty.usbmodemfa141 Using Programmer : stk500v1 Overriding Baud Rate : 19200 avrdude: Send: 0 [30] [20] avrdude: Send: 0 [30] [20] avrdude: Send: 0 [30] [20] avrdude: Recv: . [15] avrdude: stk500_getsync(): not in sync: resp=0x15
avrdude done. Thank you.
Logged
Global Moderator
Dallas
Online
Shannon Member
« Reply #33 on: June 10, 2012, 01:04:52 pm » |
Uploaded successful! Excellent! Congratulations! Small adjustment to your steps... ...
Perform a Burn Bootloader to change the fuses on the ATtiny85
... I tried several LED's w/ and w/out a resistor and there is no blink. Always with a resistor. Without a resistor can damage the processor. I know the tutorials (even the MIT ones) frequently show without but that is a mistake. what could be causing this? My suspicion is that the processor is running at 1 MHz. A program compiled to run at 8 MHz will run eight times slower if the processor is running at 1 MHz. In other words, if you wait 16 seconds (snore!) the LED will blink. Add the step highlighted above and I think you ready to play.
Logged
Offline
Jr. Member
« Reply #34 on: June 10, 2012, 03:57:42 pm » |
Went through the steps. Here's the error readout... /Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -pattiny85 -cstk500v1 -P/dev/tty.usbmodemfa141 -b19200 -e -Uefuse:w:0xFF:m -Uhfuse:w:0xD7:m -Ulfuse:w:0xE2:m
Logged
Global Moderator
Dallas
Online
Shannon Member
« Reply #35 on: June 11, 2012, 01:03:08 am » |
Uploaded successful! Argh! Stupid brain! What I read was that you successfully uploaded to the ATtiny85. Sorry about the confusion. Give me a minute to review...
Logged
Global Moderator
Dallas
Online
Shannon Member
« Reply #36 on: June 11, 2012, 01:14:26 am » |
Try this... • Prepare the Uno exactly the same way you did the last time (upload the modified ArduinoISP sketch; connect the capacitor) • Load and prepare the same Blink sketch you have been using (or copy-then-paste the following)... /* Blink Turns on an LED on for one second, then off for one second, repeatedly. This example code is in the public domain. */
void loop() { digitalWrite(0, HIGH); // set the LED on delay(1000); // wait for a second digitalWrite(0, LOW); // set the LED off delay(1000); // wait for a second } • Ensure the correct board is selected [ATtiny85 @ 8 MHz (internal oscillator; BOD disabled)] • Ensure the correct programmer is selected (Arduino as ISP) • Ensure the correct serial port is selected • Click Verify to ensure the sketch compiles. If it does not compile, resolve any problems. • Click the reset button on the Uno. The LED on pin 13 will blink a few times. Wait for the blinking to stop. • Click Upload If that works, do this... • Click the reset button on the Uno. The LED on pin 13 will blink a few times. Wait for the blinking to stop. • Click Tools / Burn Bootloader If that works, do this... • Click the reset button on the Uno. The LED on pin 13 will blink a few times. Wait for the blinking to stop. • Click Upload At this point, if everything went well, the ATtiny85 should be toggling pin 0 about once a second.
Logged
Denmark
Offline
God Member
« Reply #37 on: June 11, 2012, 06:20:13 am » |
I have tried the modified sketch in reply #30 but I get this error when I try to burn bootloader or upload blink sketch, and the Error Led pin8 is on avrdude: Version 5.11, compiled on Sep 2 2011 at 19:38:36 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "D:\Arduino_1_0\arduino-1.0-windows\arduino-1.0\hardware/tools/avr/etc/avrdude.conf"
Using Port : \\.\COM20 Using Programmer : stk500v1 Overriding Baud Rate : 19200 avrdude: Send: 0 [30] [20] avrdude: Send: 0 [30] [20] avrdude: Send: 0 [30] [20] avrdude: Recv: . [15] avrdude: stk500_getsync(): not in sync: resp=0x15
avrdude done. Thank you. I have tried to lower the Baud rate to 19200 (as far as I remember this was an advice given in another thread) To veryfy that my setup and connections are OK, I tried the exact same setup in version 0021, with success, burning bootloader, uploading blink sketch worked as expected. I have checked the boards.txt in the ver. 1.0 installation, it looks like this: ###########################################################################
attiny85at8.name=ATtiny85 @ 8 MHz (internal oscillator; BOD disabled)
# The following do NOT work... # attiny85at8.upload.using=avrispv2 # attiny85at8.upload.using=Pololu USB AVR Programmer
# The following DO work (pick one)... attiny85at8.upload.using=arduino:arduinoisp # attiny85at8.upload.protocol=avrispv2 # attiny85at8.upload.using=pololu #attiny85at8.upload.using=arduino:usbasp
attiny85at8.upload.maximum_size=8192
# Default clock (slowly rising power; long delay to clock; 8 MHz internal) # Int. RC Osc. 8 MHz; Start-up time PWRDWN/RESET: 6 CK/14 CK + 64 ms; [CKSEL=0010 SUT=10]; default value # Brown-out detection disabled; [BODLEVEL=111] # Preserve EEPROM memory through the Chip Erase cycle; [EESAVE=0]
attiny85at8.bootloader.low_fuses=0xE2 attiny85at8.bootloader.high_fuses=0xD7 attiny85at8.bootloader.extended_fuses=0xFF attiny85at8.bootloader.path=empty attiny85at8.bootloader.file=empty85at8.hex
attiny85at8.build.mcu=attiny85 attiny85at8.build.f_cpu=8000000L attiny85at8.build.core=tiny ###########################################################################
attiny85at1.name=ATtiny85 @ 1 MHz (internal oscillator; BOD disabled)
# The following do NOT work... # attiny85at1.upload.using=avrispv2 # attiny85at1.upload.using=Pololu USB AVR Programmer
# The following DO work (pick one)... attiny85at1.upload.using=arduino:arduinoisp # attiny85at1.upload.protocol=avrispv2 # attiny85at1.upload.using=pololu
attiny85at1.upload.maximum_size=8192
# Default clock (slowly rising power; long delay to clock; 8 MHz internal; divide clock by 8) # Int. RC Osc. 8 MHz; Start-up time PWRDWN/RESET: 6 CK/14 CK + 64 ms; [CKSEL=0010 SUT=10]; default value # Divide clock by 8 internally; [CKDIV8=0] # Brown-out detection disabled; [BODLEVEL=111] # Preserve EEPROM memory through the Chip Erase cycle; [EESAVE=0]
attiny85at1.bootloader.low_fuses=0x62 attiny85at1.bootloader.high_fuses=0xD7 attiny85at1.bootloader.extended_fuses=0xFF attiny85at1.bootloader.path=empty attiny85at1.bootloader.file=empty85at1.hex
attiny85at1.build.mcu=attiny85 attiny85at1.build.f_cpu=1000000L attiny85at1.build.core=tiny ########################################################################### Edit: This is the thread about lowering the baud rate http://arduino.cc/forum/index.php/topic,94609.0.htmland this about changing the delay in the heartbeat http://arduino.cc/forum/index.php/topic,108270.msg813132.html#msg813132but as far as I can see this is implimentet in the modified sketch
« Last Edit: June 11, 2012, 06:50:27 am by Erni »
Logged
Offline
Jr. Member
« Reply #38 on: June 12, 2012, 09:01:01 pm » |
I went through the steps as indicated, and when I tried to burn the boot loader, I received an error message, which was the same error message that I had posted previously, and it also happens to be the same as the error message that Erni posted.
Logged
Global Moderator
Dallas
Online
Shannon Member
« Reply #39 on: June 13, 2012, 03:08:34 am » |
Does this version work any better?
Logged
Global Moderator
Dallas
Online
Shannon Member
« Reply #40 on: June 13, 2012, 03:39:16 am » |
I have tried the modified sketch in reply #30 but I get this error when I try to burn bootloader or upload blink sketch, Before posting were you having the same problem as @Drc3p0? Did you see avrdude output identical to this... http://arduino.cc/forum/index.php/topic,108797.msg820859.html#msg820859
Logged
Denmark
Offline
God Member
« Reply #41 on: June 13, 2012, 07:25:58 am » |
Success... it works !!, I have tried burn bootloader and uploading blink sketch .. no problems. A minor problem, the hartbeat LED dosn't beat Hmm I could check, bur maybe it is less interesting, now you have solved the problem. Once again, thank you Coding Badly for maintaining the tiny core !
Logged
Dallas, TX USA
Offline
Edison Member
« Reply #42 on: June 13, 2012, 03:05:14 pm » |
To resolve these sync errors (not related to auto reset) wouldn't it be easier to just bump the RX buffer size in HardwareSerial down in the core code to avoid all these RX buffering issues? (even it is just temporary just to build the ArduinoISP sketch?)
You can have all the buffering in the world in the sketch but if the sketch can't drain the hardware serial rx buffer fast enough it doesn't matter.
avrdude is bursting the data using a 128 byte pages/chunks + 1 byte cmd + 1 byte memory type + 2 bytes length + 1 bye sync char for a total of 133 bytes. It will wait up to 5 seconds for a sync response and another 5 seconds for a successful write. So as long as you have 133 bytes of rx buffer you can take up to 5 seconds to burn the 128 bytes to flash after you report "IN SYNC" back to avrdude.
As it is now, in pre 1.0 you have 128 bytes of RX buffer so it tends to work because but in 1.0 you now only have 64 bytes with the arduino supplied core. If the sketch can keep up it can work, but in reality it doesn't 100% of the time particularly on 1.0 using the arduino 1.0 core and the heartbeat function. The transfer time of a byte at 115200 is 87us 64 bytes is about 5.5ms The heartbeat function does a delay of 20ms, depending on the timing of when that occurs, you just blew out your HardwareSerial RX buffer even if the buffer is 128 bytes.
If you bumped the rx buffer up to 256 bytes then there would be no rx buffering issue including when using the heartbeat function as the RX buffer could accommodate all 133 characters with no loss.
Wouldn't it be a lot simple to just bump RX buffer size by editing HardwareSerial.cpp and changing SERIAL_BUFFER_SIZE or RX_BUFFER_SIZE (depending on core and version) from 64 to 256 ?
That way you totally eliminate any possible rx buffer overruns.
--- bill
Logged
Global Moderator
Dallas
Online
Shannon Member
« Reply #43 on: June 13, 2012, 03:33:04 pm » |
A minor problem, the hartbeat LED dosn't beat The hearbeat code was removed. This problem is essentially the same as the "not compatible with 1.0" problem. The sad part is that I had offered a ready-to-use replacement that solves that problem and this one. When I have time I'll post a replacement with a working heartbeat. Before posting were you having the same problem as @Drc3p0? Hmm I could check, Don't. We'll just wait to hear from @Drc3p0. Once again, thank you Coding Badly for maintaining the tiny core ! You are welcome! Hopefully, someday, version 2 will be finished.
Logged
Global Moderator
Dallas
Online
Shannon Member
« Reply #44 on: June 13, 2012, 03:44:55 pm » |
To resolve these sync errors (not related to auto reset) wouldn't it be easier to just bump the RX buffer size in HardwareSerial down in the core code to avoid all these RX buffering issues? The solution is much simpler than that: Change heartbeat to blink-without-delay. I am sad to say I am not joking. Because of the way both sides work (avrdude sends then waits; ArduinoISP waits, buffers, then writes) a bigger buffer is really not necessary. I've used a modified ArduinoISP, without problems, at 9600, 19200, 250K baud and 125K, 250K, 1M SPI bitrates.
Logged
