Topic: [SOLVED] Identifying the chip at compile time (Read 5704 times) previous topic - next topic
wanderson
Jun 06, 2012, 06:09 pm Last Edit: Jun 06, 2012, 07:47 pm by wanderson Reason: 1
I am attempting to modify some code I created to take into account different register definitions for an attiny85.  I found the following #ifdef in the tiny library so I thought this would work:
Code: [Select]
#if defined( __AVR_ATtinyX5__ )
 WDTCR |= _BV(WDCE) | _BV(WDE); // WDT control register, This sets the Watchdog Change Enable (WDCE) flag, which is  needed to set the
 WDTCR = _BV(WDIE);             // Watchdog system reset (WDE) enable and the Watchdog interrupt enable (WDIE)
#else
 WDTCSR |= _BV(WDCE) | _BV(WDE);// WDT control register, This sets the Watchdog Change Enable (WDCE) flag, which is  needed to set the
 WDTCSR = _BV(WDIE);            // Watchdog system reset (WDE) enable and the Watchdog interrupt enable (WDIE)
#endif
However, when I attempt to compile the library using the board="ATtiny85@8MHz (Internal oscillator. BOD disabled)" I get an error message : "home/wandrson/sketchbook/libraries/Entropy/Entropy.cpp:51:3: error: 'WDTCSR' was not declared in this scope" which seems to indicate that it is executing the else condition rather than the ATtiny code...  I've searched and can't find a reference to what I should find defined for each of the AVR chips...  Any suggestions on where I can find that information, or if something is wrong with my syntax above?
Coding Badly
__AVR_ATtinyX5__ is defined by and specific to the Tiny Core...
http://code.google.com/p/arduino-tiny/source/browse/trunk/hardware/tiny/cores/tiny/core_build_options.h#97
core_build_options.h is also specific to the Tiny Core and disappears in the next version so I suggestion using this...
Code: [Select]
#if defined( __AVR_ATtiny25__ ) || defined( __AVR_ATtiny45__ ) || defined( __AVR_ATtiny85__ )
wanderson
CodingBadly:
Thanks for the information.  Could you give me a reference to where I could find what macros are defined for what processors, in case I incorporate other processor types.  I've search the AVR-LIBC documentation and haven't found any information.  Would prefer not to find and grep the source for the library.
Coding Badly
#3
Jun 06, 2012, 07:44 pm Last Edit: Jun 06, 2012, 07:47 pm by Coding Badly Reason: 1
I'm not aware of such a reference.  I do know that the pattern for the which-processor macro is always the same...
[font=Courier New]  __AVR_ATtiny45__[/font]
Where...
[font=Courier New]  "__AVR_"[/font] is always the prefix
[font=Courier New]  "ATtiny45" [/font]is the exact model name from Atmel's documentation
[font=Courier New]  "__" [/font]is always the suffix
You will have to consult the datasheet(s) for which processors are in which families.  There are no [font=Courier New]__AVR_ATtinyX5__[/font] like macros available from AVR-GCC or Libc.
Or did I misunderstand.  By "what macros are defined for what processors" do you also mean the "register macros"?
Quote
That's the route I've always taken.
