Topic: Can't get IRrecvDemo example to work as expected (Read 3145 times) previous topic - next topic
luxxtek
I bought the DFRobot IR Remote controller kit and tried to use it with the IRrecvDemo.
Many applications can be found that are based on the IRrecvDemo, but none seem to work for me.
Without making changes to IRrecvDemo, I tried it with IDE 23 but my Serial.print always shows 8 character values rather than the 6 character values as illustrated below
I always get 8 digit hex codes like these:
25802501
CBD2CCFD
FFFFFFFF
57E346E1
D9EF995E
B1EFBA9D
B1EFBA9D
6E2B307C
6BFD8B01
1E29FBFF
925D5B5D
1E90961
FFFFFFFF
As a result the code cannot work
else if(results.value==0xFD906F)
motor(-40,-40);
I'm sure the hardware is OK, the sample code  found here http://www.dfrobot.com/wiki/index.php?title=IR_Kit%28SKU:DFR0107%29 works OK. Note that this sample code does not use the IRremote.h library.
Any help would be appreciated.
Arduino leren ? ArdLab Gent - Lid van de STEM-Academie - www.ardlab.gent
PaulS
You can specify any value that the device received as the value to match to:
if(results.value==0xD9EF995E)
   // Got D9EF995E...
JoeO
luxxtek
* IRremote: IRrecvDemo - demonstrates receiving IR codes with IRrecv
* An IR detector/demodulator must be connected to the input RECV_PIN.
* Version 0.1 July, 2009
* Copyright 2009 Ken Shirriff
* http://arcfn.com
#include <IRremote.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
  irrecv.enableIRIn(); // Start the receiver
  if (irrecv.decode(&results)) {
    Serial.println(results.value, HEX);
    irrecv.resume(); // Receive the next value
PaulS
The code that tries to use the values that you have recorded, not the code that printed them.
luxxtek
I'm at the office right now, can't access the sketch I used to test.
I"ll post it tonight.
Thanks so far.
JoeO
I have the exact same IR remote.
One side note:
The FFFFFFFFs are the remote sending the repeat code if you hold the button down too long.
luxxtek
Here is the code. For testing I only added to check if the  "VOL +" button is pressed.
Results are not very consistent and I wonder why I don't see the codes as shown here
as explained on this page http://www.e-shore.com.my/homepage/all-projects/193-ir-remote-control-mobile-robot.html
Do various versions of this remote exist ? I would expect them to use the same hex codes
* http://arcfn.com
int RECV_PIN = 11;
    if(results.value==0xC9C3741)
      Serial.println("VOL + pressed");
      Serial.println("other button pressed");
JoeO
This line
Should be:
  if(results.value==0xFD807F)
Yes, I have one that is physically and coded the same but has a different plastic overlay.
http://www.adafruit.com/products/389
JoeO
I downloaded your code, put my fix on it and it decodes the VOL+ equivalent key on my remote.
It decodes all of the remote's keys.
There may be a problem in your hardware.  Please post good pictures so that individual wires/connections can be traced.
JOe
luxxtek
I have this one
http://www.dfrobot.com/index.php?route=product/product&product_id=366
and apparently it generates different codes
My code works but sometimes buttons are missed and I have to press again to get a positive result.
I was confused because I thought I read abnormal HEX codes  but I looks like a have an  IR remote control that sends different codes.
JoeO
I agree with you, the code is fine.  I also believe that the remote control is correct.
There is something else going on, battery in the remote control is bad or something is wrong in the arduino hardware.
Good luck.
