Topic: quick help -- button pressing and timing (Read 4337 times) previous topic - next topic
daatse
i am not quite sure what the problem is but it may just be that something called 'contact bounce' is at work here
please look this up
i made a small tweak to the code
try this code:
Code: [Select]
boolean status;
void setup(){
Status == digitalRead(5)
void loop(){
        if (digitalRead(5) == FALSE && status == TRUE){
                  Serial.println("5");
                  status = FALSE;
        if (digitalRead(5) == TRUE){
                  status = TRUE;
delay(20);
if contact bounce is the issue the code above should do the trick, also experiment with the delay time to find the minimum value for application because else it would slow down the whole loop
scales11
#16
Jul 03, 2012, 12:48 pm Last Edit: Jul 03, 2012, 12:49 pm by scales11 Reason: 1
Yes I think that delay could fix it, but I was trying not to use delays so that I wouldn't miss key presses.  Do you think using some of the "Blink without Delay" code would fix it?
http://arduino.cc/en/Tutorial/BlinkWithoutDelay
Also, while I am currently using a button, I would like to switch to a rotary encoder.  I am not sure what that will do to my code.
daatse
in my prev sketch Status == digitalRead(5) --> Status = digitalRead(5)
yes the blink without delay example will do fine just implement it in the right way
sketch:
Code: [Select]
#define contactbounce 20
boolean status;
unsigned int time;
void setup(){
time =millis()
void loop(){
if (millis()+contactbounce>= time){
                  status = FALSE;
                  status = TRUE;
time = millis()
i never worked with rotaty encoders myself but ill bet there is some code for them somewhere on the arduino forum
some links:
http://arduino.cc/en/Tutorial/Debounce
http://arduino.cc/playground/Main/RotaryEncoders
PaulS
Code: [Select]
unsigned int time;
void setup(){
time =millis()
Aside from the milling semicolons, this code is a disaster waiting to happen.
millis() returns an unsigned long, not an unsigned int. Storing the value in an unsigned int will result in mangled data.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
