Topic: Which Maxsonar rangefinder do you suggest? (Read 1 time) previous topic - next topic
Archelon
Hello I'm about to start with a robotproject, the robot will be able to scan a room in 2 dimensions with some kind of rangefinder and then do something with that data.
I've been looking for a while and it seems like the maxsonar LV-EZ series has the right price and abilities.
Now I wonder which one should I go for, the LV-EZ 0, 1, 2 or 4? I do not really understand where they specify the beam width in the datasheet so I have a hard time choosing between them.
thanks for your help!
AWOL
Quote
What is it that you don't understand?
Generally, for mapping, I'd use the narrowest beam possible.
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
Archelon
Quote
excuse me, I just found the Beam width explanation file.. :P
seems like the ez4 is the one with the narrowest beam width so I'll go for that one :)
teckel
The EZ4 also has the shortest range, keep that in mind if range is important.  I would suggest the EZ3, as it has about the same width beam but the range is much longer.
I have two problems with the Maxsonar sensors.  First, they can't detect objects closer than 6 inches, which in many cases is important.  Secondly, while it has a robust set of interface options (analog voltage, serial & pulse width), it's not compatible with most ultrasonic libraries and sketches.  This limits you to using their interface code/library or developing your own.
I've never used a Maxsonar sensor so I don't know if there's other issues (like ping speed) which could be important when used as a scanner.
Tim
My platforms Arduino, Teensy 3.2, Arduino Pro Mini, ATmega328
My libraries: NewPing, LCDBitmap, toneAC, toneAC2, NewTone, TimerFreeTone
My projects: https://dogblocker.com & https://baconorbeer.com
My beer: Great Lakes Brewing Co. Lake Erie Monster
jraskell
You should come at the problem from the other angle.  Ask yourself the following two questions:
What's the smallest object in the room you want your robot to be able to detect?
What's the maximum range you want to be able to detect that object at?
Once you have the answer to those two questions, look at the datasheets and find the rangefinder that most closely matches your criteria.
Just be forewarned, you may find that the one that most closely matches your criteria doesn't actually come close to matching it.
