Pages: [1] 2   Go Down
Author Topic: hex/byte to int conversion  (Read 758 times)
Hey, quick question.  How do I convert both of these into an int (which should have a value of 123) -
- a char[2] containing "7B"   (ie as hex)
and
- a char[1] containing "{"   (ie as an ascii byte)
thanks!
UK
Online Online
int x = (int) char [1];
For brevity, you can omit the cast.
Manchester (England England)
Solder is electric glue
int v1 = int(char[2] );
int v2 = int(char[1] );
UK
What a host of balls she had seen: gaity, the brass buttons...
[quote]- a char[2] containing "7B"   (ie as hex)[/quote]
[code]
char *foo="{";
int bar = (int)char[0];
unsigned char h2d(char hex)
        switch(hex)
                case '0':       return 0;
                case '1':       return 1;
                case '2':       return 2;
                case '3':       return 3;
                case '4':       return 4;
                case '5':       return 5;
                case '6':       return 6;
                case '7':       return 7;
                case '8':       return 8;
                case '9':       return 9;
                case 'a':       return 10;
                case 'A':       return 10;
                case 'b':       return 11;
                case 'B':       return 11;
                case 'c':       return 12;
                case 'C':       return 12;
                case 'd':       return 13;
                case 'D':       return 13;
                case 'e':       return 14;
                case 'E':       return 14;
                case 'f':       return 15;
                case 'F':       return 15;
        return 0;
unsigned char h2d2(char *hex)
        return (h2d(hex[0])<<4) | h2d(hex[1]);
char *foo="7B";
int bar = h2d2(foo);
Or something similar.
[/code]
« Last Edit: June 07, 2012, 04:14:14 pm by majenko » Logged
UK
Online Online
- a char[2] containing 0x7B   (ie as hex)
You don't need two chars to hold two hex digits, unless they're stored as their character representation
char x[0] = '7';
char x [1] = 'B';
California
I misinterpreted what he was doing, I thought he was talking about the hex value being in a single char.
Thanks guys, a stunning response!
Yes, "they're stored as their character representation" because they've just been read as characters from a text file
the ascii example works great.
However majenko's switch code to convert from hex gives me the following error -"invalid conversion from char* to unsigned char*"    Know what's up?
UK
I copied it from another one of my projects and modified it to suit on the fly.  Experiment with it.  It'll be the passing of the char * variable.  I had it working with two plain char variables originally.
Just remove the "unsigned" bits from the function definitions.  Those were left over from my other project.
majenko - I thought you were having a joke with that code. But if you were serious then this is much better than using case statements.
int convertFromHex(int ascii){
  if(ascii > 0x39) ascii -= 7; // adjust for hex letters upper or lower case
  return(ascii & 0xf);
Yorkshire England
Arduino good init
Mike why is that last method better than using casting? Is their a difference in how it complies?
UK
I am sure it is, but at 3AM in the morning my brain wasn't up to counting the characters in between the numbers and the letters.  And as I was up at 4AM this morning to drive across the country and back, my brain hasn't yet been up to the task of re-writing it better.
Mind if I steal your little snippet there?  Although, from a pure processing point of view, which is better - a lookup table, or a condition and a mathematical calculation?  (If I were doing it in PIC ASM it would be a lookup table with RETLW's offset by the PC + the W register).
UK
Oh... and integers to store a single byte...? On an 8-bit processor...?!
How wasteful...
Be my guest.
If it was in assembler my method would be shorter to code, and not take up as much space.  I haven't analised the code to see if it would run faster.
Get some sleep.
Remember bed is your friend.  smiley
Well in the original code I had it return long ints but this was because it was to do with RFID token codes.  smiley-razz
but I'm trying to convert from a char array, of size 2, containing a hex in string form.... I don't get it
UK
This converts one character.  My post contained 2 functions.  The first one is the same as this function.  The second one takes a string of 2 characters and calls the first function for each character.
Keep my second function, but replace my first one (h2d) with this one.
Pages: [1] 2   Go Up
