Topic: randoms servos and a display (Read 1 time) previous topic - next topic
artvantriest
hi people
need a little help here, I attached my patch, could somebody have a look at  it?
what I am trying to do is this:
generating random numbers and showing them on the display
make one servo move according to other random numers
make the servo move from one point to another and back IF the randomnumber is 0666
what happens is:
the random numbers are displayed at the display
but the random servo only moves one time, then it stops....
I cant figure out what I am doing wrong, could somebody give me some advice?
thanx a lot
art
johnwasser
Code: [Select]
int potpin = 0;  // analog pin used to connect the potentiomete
val = random(potpin);
That's not going to do anything useful.
Code: [Select]
if (randNumber = 0666)
That's doing an assignment, not a comparison.
Code: [Select]
  myservo2.write(500);
500 is outside the range 0 to 180.
If anyone else wants to point out other possible problems:
Code: [Select]
// Controlling a servo position using a potentiometer (variable resistor)
// by Michal Rinott <http://people.interaction-ivrea.it/m.rinott>
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
Servo myservo2;  // create servo object to control a servo
int val;    // variable to read the value from random
// library
#include <SoftwareSerial.h>
// Pin for 7 segment display
#define rxPin 2
#define txPin 3
SoftwareSerial mySerial =  SoftwareSerial(rxPin, txPin);
long randNumber;
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  myservo2.attach(11);  // attaches the servo on pin 9 to the servo object
  // define pin modes for tx, rx, led pins:
  pinMode(rxPin, INPUT);
  pinMode(txPin, OUTPUT);
  // randomSeed(analogRead(0));
  // print a random number from 0 to 9999
  randNumber = random(10000);
  mySerial.print(randNumber);
  randNumber = random(1023);
  val = random(potpin);            // reads the value of the potentiometer (value between 0 and 1023)
  val = map(val, 0, 1023, 0, 179);     // scale it to use it with the servo (value between 0 and 180)
  myservo.write(val);                  // sets the servo position according to the scaled value
  delay(30);    // waits for the servo to get there
    myservo2.write(0);
  delay (500);
  delay (500);
  myservo.write(0);
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
PaulS
Code: [Select]
You have a mySerial attached to those two pins? What IS a mySerial? Meaningful names are not only allowed, they are strongly recommended.
Code: [Select]
It is NOT necessary to use PWM pins for servos. Don't these servos have any physical function that would lend better names? Did you name your kids myChild and myChild2?
Code: [Select]
But, you've told the SoftwareSerial instance that these are its pins. Why are you messing with them?
Code: [Select]
The code does NOT do what the comment says. Fix or delete the comment or the code (or both).
Nick Gammon
Code: [Select]
This is better written as:
Code: [Select]
SoftwareSerial mySerial (rxPin, txPin);
Your method (perhaps not obviously) makes a second unnamed SoftwareSerial object and copies that into mySerial.
Code: [Select]
  myservo2.write(0);
  delay (500);
  delay (500);
  myservo.write(0);
Are you expecting to do one thing after the "if" or all those lines?
Code: [Select]
0666
That is octal 666 (438 in decimal). Is that intentional?
Also, as johnwasser said, you need == rather than =.
Next time post your code into the message, inside [code] tags.
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
artvantriest
thnx you all for the advice:
@johnwasser and PaulS , got rid of the potpin
@Nick Gammon fixed the softwareserial mumbojumbo
now indeed I want all those lines done if the randomnumber is 0666
number 0666 is not picked intentional
so then the code is:
Code: [Select]
#include <Servo.h>
int val;    // variable to read the value from the analog pin
// library
#define rxPin 2
#define txPin 3
long randNumber;
   mySerial.begin(9600);
  delay(15);    // waits for the servo to get there
  if randNumber == (666)
  myservo.write(0);
  delay (500);
  myservo.write(90);
  delay (500);
  myservo.write(0);
[code]
[/code]
artvantriest
ok I made some adjustments
now this is what I have, and everything works
except the second servo...
I have it on a seperate powersource via the vin-pin
strange no?
any more ideas?
Code: [Select]
#include <Servo.h>
int val;
// library
#define rxPin 2
#define txPin 3
long randNumber;
  val = randNumber;
  delay(500);    // waits for the servo to get there
  if (randNumber == 666)
{ delay (2000);
  myservo2.write(0);
  myservo.write(0);
  delay (2000);
  myservo2.write(90);
  myservo.write(90);
  delay (2000);
  myservo2.write(0);
  myservo.write(0);
PaulS
Quote
Which does what? It doesn't appear that you took most of what I said seriously.
Nick Gammon
Doesn't New York has 42nd Street and 43rd Street?
I'm trying to work PaulS1 and PaulS2 into a funny line, but can't quite do it.
More info:
artvantriest
hehehe
enough with the namecalling! ;-)
as long as it works, it works
point is that it doesnt
but why?
here's my latest code till now
only the myservo2 (sry paulS) stuff does not work
Code: [Select]
#include <Servo.h>
int val;
// library
#define rxPin 2
#define txPin 3
long randNumber;
  val = randNumber;
  if (randNumber == 6666)
{ delay (2000);
  myservo2.write(0);
  myservo.write(0);
  delay (2000);
  myservo2.write(90);
  myservo.write(90);
  delay (2000);
  myservo2.write(0);
  myservo.write(0);
dxw00d
Quote
http://www.brooklyn.com/streetsindex.html#numbered
Quote
Code: [Select]
{ delay (2000);
  myservo2.write(0);
  myservo.write(0);
  delay (2000);
  myservo2.write(90);
  myservo.write(90);
  delay (2000);
  myservo2.write(0);
  myservo.write(0);
I don't think that a random number, in the range 0 to 1022, will ever be equal to 6666.
artvantriest
true, I noticed that
and I also noticed that the uploading is not right, ill try to fix that and come back to uguys!
art
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
