Offline
Newbie
« on: June 08, 2012, 05:20:13 am » |
Hello Arduino Forum, I'm (hopefully) going to make a musical instrument with lasers instead of strings for my final school project. I will use 8 lasers and 8 LDRs. All lasers will have a dedicated LDR they are pointing at, and if the contact is interfered, a MIDI signal will be generated. I just drew the schematics:  . I don't have an awful lot of experience with (complex) electronics, and I'm hoping you could give me some advice/corrections. As you can see I will have two circuits, one for the lasers and one for the LDRs and the arduino. The lasers (20mw green diodes) use 3v and 250mA, and I want to be able to plug it into a wall sockets, hence the transformer. Thanks in advance! Edit: The image doesn't seem to work, so here is the link: http://postimage.org/image/swhfyjyed/full/
« Last Edit: June 08, 2012, 05:22:36 am by Aeryck »
Logged
Global Moderator
UK
Offline
Brattain Member
I don't think you connected the grounds, Dave.
« Reply #1 on: June 08, 2012, 05:28:51 am » |
The lasers (20mw green diodes) Why such powerful devices?
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline
Newbie
« Reply #2 on: June 08, 2012, 05:35:13 am » |
The lasers (20mw green diodes) Why such powerful devices? I want to be able to see the beams. I guess I could use 5mw, but will those be visible? (I have acces to a smoke-machine)
Logged
Global Moderator
UK
Offline
Brattain Member
« Reply #3 on: June 08, 2012, 06:11:54 am » |
I want to be able to see the beams. I Get it wrong, and they could be the last things you see clearly!
Logged
Offline
Newbie
« Reply #4 on: June 08, 2012, 06:58:26 am » |
I want to be able to see the beams. I Get it wrong, and they could be the last things you see clearly! They wont be pointing towards people, but on an LDR, so once installed it's completely safe. Something else: Is my drawing correct? I was wondering if it is possible to just draw the cable through all the cables after the LDRs, and connect it to the ground (like i've drawn)
Logged
Gosport, UK
Offline
Faraday Member
« Reply #5 on: June 08, 2012, 07:36:36 am » |
so once installed it's completely safe. Provided nothing can deflect the beam.
Logged
Montreal
Offline
Edison Member
Per aspera ad astra.
« Reply #6 on: June 08, 2012, 09:15:10 am » |
I don't think the drawings is correct. You need 8 resistors in series with LDR to form a voltage dividers, than connect middle point to digital input. Probably, you could activate internal pull-up resistors for this, than LDR would be between input and ground (not +5V). The powering lasers using transformer is also not gonna work right, lasers would light up for short period of time, so your LDR would constatnly read 50/60 Hz square wave, not saying that forward peak current should be limited somehow.
Logged
Dubuque, Iowa, USA
Offline
Edison Member
« Reply #7 on: June 08, 2012, 09:19:22 am » |
FYI a LDR has much slower response than a phototransistor or photodiode. If you're moving your hand through the beams slowly it won't be an issue, but it would be possible to move your hand through quickly enough to miss the signal. I'd also suggest adding a way to switch the lasers on/off so you can calibrate your sensors. Turn the lasers off, take a reading, turn them on, take a reading, then set your threshold somewhere in between. As Magician mentioned:
Logged
Gosport, UK
Offline
Faraday Member
« Reply #8 on: June 08, 2012, 09:22:22 am » |
All the LDRs in the original image are connected to digital inputs. I'm not sure how you would calibrate that.
Logged
Global Moderator
UK
Offline
Brattain Member
« Reply #9 on: June 08, 2012, 09:40:20 am » |
With a soldering iron.
Logged
Dubuque, Iowa, USA
Offline
Edison Member
« Reply #10 on: June 08, 2012, 09:55:07 am » |
Indeed. In that case the OP needs to use a variable resistor in place of the fixed resistor to calibrate the sensitivity of the LDRs.
Logged
Offline
Newbie
« Reply #11 on: June 09, 2012, 06:50:10 am » |
http://www.ladyada.net/learn/sensors/cds.htmlIf you scroll down it says how to connect LDRs to digital inputs, although I will have to edit my schematics for it. I don't think the drawings is correct. You need 8 resistors in series with LDR to form a voltage dividers, than connect middle point to digital input. Probably, you could activate internal pull-up resistors for this, than LDR would be between input and ground (not +5V). The powering lasers using transformer is also not gonna work right, lasers would light up for short period of time, so your LDR would constatnly read 50/60 Hz square wave, not saying that forward peak current should be limited somehow. Thanks for the feedback, I'll look into the resistors, although I doubt I will need them (check out the link above) Also, why would the lasers not work? If the transformer turn 220v AC into 24v DC, it should work, right?
Logged
Montreal
Offline
Edison Member
« Reply #12 on: June 09, 2012, 08:03:06 am » |
I'll look into the resistors, although I doubt I will need them (check out the link above) Not sure you are looking at the same drawing, but picture in the "Analog voltage reading method" section shows 10k resistor in series with LDR. Also, why would the lasers not work? If the transformer turn 220v AC into 24v DC, it should work, right? Wrong, transformer outputs 24 AC, according to your drawings.
Logged
Manchester (England England)
Offline
Brattain Member
Solder is electric glue
« Reply #13 on: June 09, 2012, 11:18:31 am » |
Also, why would the lasers not work? If the transformer turn 220v AC into 24v DC, it should work, right? As well as the fact you are feeding it with AC, there is nothing to limit the current. You will blow all the lasers. Driving a laser is far more complex than this see:- See this for how to do it. http://www.repairfaq.org/sam/laserdps.htm
Logged
Offline
Newbie
« Reply #14 on: June 10, 2012, 05:48:14 am » |
I'll look into the resistors, although I doubt I will need them (check out the link above) Not sure you are looking at the same drawing, but picture in the "Analog voltage reading method" section shows 10k resistor in series with LDR. Also, why would the lasers not work? If the transformer turn 220v AC into 24v DC, it should work, right? Wrong, transformer outputs 24 AC, according to your drawings. At the bottom of the page it says: "BONUS! Reading photocells without analag inputs". As I've stated, I will use digital pins, not analog ones, because I won't have enough of those. According to the drawings, I'll just need 0.1 uF ceramic condensators. About the transformer: I now see my drawing was wrong. I've been searching, and found this: http://www.security-systems.nl/377-Diversen/220V/110V-50Hz/60Hz-24V-DC-250mA-Power-Supply.html. But as Grumpy_Mike has said, it probably wont be that easy to power the lasers, since they will blow up at a current peak. BTW, thanks for all the feedback guys!
Logged
