Topic: Shift register led patterns (Read 2007 times) previous topic - next topic
bld
I am trying shift registers for the first time, and would like to be able to make patterns for how the leds would be turned on and off.
Right now I got this test code running, which is just a boring sweep...
int dataPin = 2;        //Define which pins will be used for the Shift Register control
int latchPin = 3;
int clockPin = 4;
int seq[14] = {1,2,4,8,16,32,64,128,64,32,16,8,4,2};       //The byte sequence
    pinMode(dataPin, OUTPUT);       //Configure each IO Pin
    pinMode(latchPin, OUTPUT);
    pinMode(clockPin, OUTPUT);
    for (int n = 0; n < 14; n++)
        digitalWrite(latchPin, LOW);             //Pull latch LOW to start sending data
        shiftOut(dataPin, clockPin, MSBFIRST, seq[n]);          //Send the data
        digitalWrite(latchPin, HIGH);            //Pull latch HIGH to stop sending data
        delay(75);
But how would I do it if I would have multiple pins enabled? like 00011000 then 00100100, followed by 01000010...
captain-slow.dk | non contagious!
Osgeld
you just make an array with the patterns as bits
byte seq = {B00011000,B00100100,B01000010}
marco_c
Here's code I wrote a long time ago to make patterns. See if you can figure out how to make your from this. FYI my LEDs were in a circle.
// 595 tester
//Pin Definitions
//The 74HC595 using a protocol called SPI (for more details http://www.arduino.cc/en/Tutorial/ShiftOut)
//Which has three pins
#define  DATA_PIN  10
#define  CLOCK_PIN  9
#define  LATCH_PIN  8
#define  MAX_LED    8  // the number of LEDs we want to flash, should be a number >= 2
#define  MAX_REPEAT 2  // the maximum number of times each sequence will repeat
#define  PAUSE_DELAY  100  // delay between each LED animation on/off
#define  DEBUG  1  // Enable Debugging code if required
//Used for single LED manipulation
int ledState = 0;
const int ON = HIGH;
const int OFF = LOW;
  // We set the three control pins to outputs
  pinMode(DATA_PIN, OUTPUT);
  pinMode(CLOCK_PIN, OUTPUT);
  pinMode(LATCH_PIN, OUTPUT);
#if  DEBUG
  Serial.begin(57600);
  Serial.println("[LED Sequence Flasher]");
#endif
void updateLEDs(byte value, boolean bReverse, int nPause)
// Handle the interface to the 74HC595 to write the 8 bits of the byte
// Optionally reversethe bit string and then delay at the end
  if (bReverse) value = ~value;
  digitalWrite(LATCH_PIN, LOW);  //Pulls the chips latch low
  shiftOut(DATA_PIN, CLOCK_PIN, MSBFIRST, value); //Shifts out the 8 bits to the shift register
  digitalWrite(LATCH_PIN, HIGH);   //Pulls the latch high displaying the data
  if (nPause != 0) delay(nPause);
void Sequence01(boolean bReverse)
// Flash each LED in sequence
#if  DEBUG
  Serial.println("Seq 01");
#endif
  for (byte i=0; i<MAX_LED; i++)
    updateLEDs((1 << i), bReverse, PAUSE_DELAY);
void Sequence02(boolean bReverse)
// Scan back and forth
#if  DEBUG
  Serial.println("Seq 02");
#endif
  for (byte i=MAX_LED-1; i>0; i--)
void Sequence03(boolean bReverse)
// Start at each end towards the middle
#if  DEBUG
  Serial.println("Seq 03");
#endif
  for (byte i=0; i<MAX_LED/2; i++)
    updateLEDs((1 << i) | (1 << MAX_LED-i-1), bReverse, PAUSE_DELAY);
void Sequence04(boolean bReverse)
// Start in the middle towards each end
#if  DEBUG
  Serial.println("Seq 04 ");
#endif
  for (int i=MAX_LED/2-1; i>=0; i--)
void Sequence05(boolean bReverse)
// Start at each end towards the middle, cross over and keep going
// Looks like they bounce off each other!
#if  DEBUG
  Serial.println("Seq 05");
#endif
    updateLEDs((1 << i) | (1 << MAX_LED-i-1), bReverse, ((i==MAX_LED/2) ? PAUSE_DELAY/2 : PAUSE_DELAY));
void Sequence06(boolean bReverse)
// Bouncing ball, each bounce is one less LED
  byte  j;
#if  DEBUG
  Serial.println("Seq 06");
#endif
    for (j=0; j<MAX_LED-i-1; j++)
      updateLEDs((1 << j), bReverse, PAUSE_DELAY);
    for ( /* wherever j is from before */; j>0; --j)
void Sequence07(boolean bReverse)
// Binary counter
  int maxCount = (1<<MAX_LED)-1;  // use up all the bits in the number
#if  DEBUG
  Serial.println("Seq 07");
#endif
  for (int i=0; i<maxCount; i++)
    updateLEDs(i, bReverse, PAUSE_DELAY/4);
  static int  n = 0;
  static boolean bReverse = false;
  switch (n/MAX_REPEAT)  // repeat each sequence MAX_REPEAT times
    case 0:  Sequence01(bReverse);  break;
    case 1:  Sequence02(bReverse);  break;
    case 2:  Sequence03(bReverse);  break;
    case 3:  Sequence04(bReverse);  break;
    case 4:  Sequence05(bReverse);  break;
    case 5:  Sequence06(bReverse);  break;
    case 6:  Sequence07(bReverse);  break;
    default:
      n=-1;    // reset the loop counter - it gets incremeted again at the end of loop()
      bReverse = ~bReverse;
  n++;  // increment the loop counter for next time
Arduino Libraries https://github.com/MajicDesigns?tab=Repositories
Parola for Arduino https://github.com/MajicDesigns/Parola
bld
Awesome! :)
Just tested the code, and it worked right away, just need to take it apart now to make it fit what I need, thank you! :D
My led's will be in a circle too, going to be 8 under this.
bld
And I actually ended up using this way instead, fits my application a bit better :)
