Loading...
Pages: [1]   Go Down
Author Topic: General circuit design question on motors/relays/inductors  (Read 439 times)
Offline Offline
Newbie
View Profile
Hi Everyone,
Can someone explain why is the diode connected between two ends of an inductor (motor, mechanical realays, etc) is in the opposite direction of current flow?
For example, show in this picture: http://itp.nyu.edu/physcomp/uploads/arduino_bb_pot_transistor_motor_diode.png
I know what its purpose is (to protect the transistor from back EMF of the motor when it is shutting down), but I just can't understand why it is in the opposite direction of current flow.
Thank You
Logged
0
Offline Offline
Faraday Member
ruggedcircuits.com
View Profile
WWW
Well, if the diode was reversed so it would be "with" the current flow, the current would flow through it rather than the motor! Not what you want.
The reason for its orientation is to complete a circuit. The circuit has electrons starting at the inductance (motor, relay coil, etc.) and having to somehow find their way to the other side of the inductance. This is because the external circuit has been switched off (to de-energize the inductance) yet the inductance, as it loses energy, creates its own current flow. Without a path for that current flow (which is in the same direction as the flow that was there before it was switched off), it will find a way through the insulation of the coil, through the air (if powerful enough), and you generally won't like the results. The diode provides a safe path for that decaying current.
The Rugged Audio Shield: Line In, Mic In, Headphone Out, microSD socket, potentiometer, play/record WAV files
Logged
Offline Offline
Newbie
View Profile
So basically, the diode is to trap the decaying current inside the coil?
Logged
0
Offline Offline
Faraday Member
ruggedcircuits.com
View Profile
WWW
Close, the diode is to allow the decaying current to flow through a safe, well-defined path. Rather than punching holes in the coil's insulation for example.
The Flexible MIDI Shield: MIDI IN/OUT, stacking headers, your choice of I/O pins
Logged
Offline Offline
Newbie
View Profile
Ok. Thank you so much for clearing things up.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Think of the electrons in an inductor as magically acquiring a lot of momentum - they don't want to change their speed quickly and can do damage if you try to stop them dead...
Logged
Pages: [1]   Go Up
Print
Jump to:
