« on: June 08, 2012, 10:58:54 pm » |
hi guys , when i press reset button, kit does nothing no LED(rx,tx. pin 13) blinks or when i try to burn new sketches"avrdude: stk500_getsync(): not in sync: resp=0x00" error comes. i used both (USB and powerjack) supplies at same time, but i worked for some days quite well before this thing happened . now i am stuck with this problem and i have to complete my project as soon as possible.I think my kit has burnt really need some help guys!!!! thanx in advance...
"The old Europe"
Bootloaders suck!
« Reply #1 on: June 09, 2012, 01:27:15 am » |
Unplug everything that is not an integral part of the arduino board, do the loop-back test and report back. The links is down below.
If any part should get hot to the touch please unplug asap.
It would also be nice if you told us what kind of hardware (link!) and operating system you use.
• Upload doesn't work? Do a loop-back test. • There's absolutely NO excuse for not having an ISP! • Your AVR needs a brain surgery? Use the online FUSE calculator. • My projects: RGB LED matrix, RGB LED ring, various ATtiny gadgets... • Microsoft is not the answer. It is the question, and the answer is NO!
Forum Moderator
Bangalore, India
« Reply #2 on: June 09, 2012, 01:35:40 am » |
Are you using the official Arduino? If yes which model? If not can you point to the link of your clone?
« Reply #3 on: June 09, 2012, 06:20:38 am » |
i removed external ckt... and tried still no luck. currently I am using arduino uno(original) and my operating system is windows 7.Correct me if am wrong, by loop test you mean shorting rx and tx pin in board,if it is correct then in that case whatever i sent from serial monitor got that back. If i am wrong about loop test plz let me know what it is ??? I am new to arduino.Can i replace microcontroller in arduino board with new Atmega 328 PU..
« Last Edit: June 09, 2012, 06:28:53 am by deepakvnit »
"The old Europe"
Bootloaders suck!
« Reply #4 on: June 09, 2012, 10:56:34 am » |
You can replace the AVR chip. However, you must make sure that
a) you get a new chip with a bootloader preprogrammed
or
b) you have a programmer or 2nd arduino board to precondition the new chip.
If that is the problem.
The loop-back test is clearly described in the link.
« Reply #5 on: June 09, 2012, 11:23:47 pm » |
MADWORM thanx for your help!!!!!! i tried loop back test as mentioned in link. and it worked out fine. does this mean my arduino kit is not damaged. but problem is that i don't have another kit so is there another way to burn bootloader in new atmel. can i directly burn bootloader after replacing burnt atmega 320.
« Last Edit: June 10, 2012, 03:40:53 am by deepakvnit »
Chennai, India
Peace!!!
« Reply #6 on: June 13, 2012, 12:10:52 am » |
Hi Deepak,
Looks like you have a corrupt bootloader / no bootloader on the IC. Where did you buy it from? if you have another arduino / avr programmer with you, you can reprogram the bootloader.
cheers, Pracas
Be The Change...
Forum Moderator
ਪੰਜਾਬ
WANTED! A Girl with LOVE for me and Arduino!
« Reply #7 on: June 22, 2012, 12:39:58 pm » |
What;s the status of your problem now? are you done with it, Solved!!??
"Real Men can Accomplish Anything" - Website - skype : nishants5 ਫ਼ਤੇਹ ਕਰੂਂ !
« Reply #8 on: June 26, 2012, 02:02:26 am » |
hi nishant!!!! well I browsed through some stuff in internet came know about few methods about bootloading the new chip viz.(bit bang, rs232) but my bad luck i have arduino uno r1 which doesn't have pin for bitbang method and my laptop doesn't support RS232...... so i ordered new ATMEGA (bootloaded) and hoping for it to arrive soon. I want to know that since we ATMEGA 8u2 for usb to serial conversion then can we use this to burn the code(if i am correct)???????
« Reply #9 on: June 27, 2012, 10:20:20 pm » |
I don't know what is wrong with arduino..... i got my new bootloaded ic ... connected that ATMGA in arduono board successfully burnt first LED blinking program after that all of sudden started getting same error as before. "AVR DUDE NOT IN SYNC".......
« Last Edit: June 27, 2012, 10:38:01 pm by deepakvnit »
Forum Moderator
ਪੰਜਾਬ
« Reply #10 on: June 28, 2012, 12:01:13 am » |
well I browsed through some stuff in internet came know about few methods about bootloading the new chip viz.(bit bang, rs232) but my bad luck i have arduino uno r1 which doesn't have pin for bitbang method and my laptop doesn't support RS232...... so i ordered new ATMEGA (bootloaded) and hoping for it to arrive soon. I want to know that since we ATMEGA 8u2 for usb to serial conversion then can we use this to burn the code(if i am correct)??????? ] UNO R1 has a ICSP header pinout avaialable you just need to insert the 3x2 male header into the place there and can be programmed using the USBASP or AVR MKII programmer. and RS232 port is every here how come your laptop does not have it,what is the model. and if you have played and changed the code on your ATmega8u2 then you cannot upload code to it no matter how new and fresh the main Bootloaded ATmega328 is.
« Reply #11 on: June 28, 2012, 12:45:09 am » |
@nishant, well i didn't play with atmega 8u2 even if it was so how come it burnt the code first time.these days laptops have only ports for VGA cable RS 232 port can be created by using usb to serial converter.As far as my laptop model is concerned i am using "Compaq presario CQ62".For using ICSP header one need to have avr programmer which i don't have.Now I am in very bad situation as i have to complete my project in less than 10 days and i don't have any other option available.Can you explain what can go wrong in burning a program(i burnt led blinking program given in example). i think there is some problem with reset. let me explain in details when i got my new bootloaded ic, after connecting it to board when i pressed reset button led connected to pin 13 blinked 3 times(which should). after that i burnt the program in atmega and led started blinking in interval of 1 sec. after that i tried to burn other program(avrisp) which resulted in error. now when i press reset button nothing happens. only previous prgram(led blinking) keeps on running.now can you suggest any thing??????
Forum Moderator
ਪੰਜਾਬ
« Reply #12 on: June 28, 2012, 12:58:03 am » |
You have loaded the AVRISP that is why its being a problem now its in the burning mode that is working as a programmer and now you can't unpload anyther sketch simply do some manual ressetting the board , so when you click on upload button on your IDE look for the prompt that says "Binary sketch size: " as ASAP click the reset button this may manually reset the board and then let the sketch load into the ATMEGA.
« Reply #13 on: June 28, 2012, 01:40:59 am » |
@nishant first i wasn't able to upload avrisp successfully and i tried to reset the board manually nothing helps!!!!!!
Forum Moderator
ਪੰਜਾਬ
« Reply #14 on: June 28, 2012, 10:27:23 am » |
i pre suppose that you have already reinstalled the drivers for the system, i mean arudino iDE and the UNO drivers.
Now even if the things do not work then i think somethings bad with the 8u2 firmware!
