Topic: PCF8574 Expander Library (Read 6591 times) previous topic - next topic
wlewis
Jun 10, 2012, 02:15 am Last Edit: Jun 10, 2012, 02:19 am by wlewis Reason: 1
Here's a library for the PCF8574 in case anybody wants it. This works in v1.00 - if anybody wants to alter it for v1.01 please do so.
The .h file >
Code: [Select]
// pcf8574 lib by william lewis
#ifndef PCF8574_h
#define PCF8574_h
#include <inttypes.h>
class PCF8574Class
 public:
   void Prox(int, int, int);
   void Set(int, int);
 private:
   int read(int);
   void write(int, int);
extern PCF8574Class PCF8574;
#endif
The .cpp file >>
Code: [Select]
#include <Wire.h>
#include "PCF8574.h"
static int current_data;
static int state;
int pin_array[2][8] = {
 0B01111111, 0B10111111, 0B11011111, 0B11101111, 0B11110111, 0B11111011, 0B11111101, 0B11111110,
 0B10000000, 0B01000000, 0B00100000, 0B00010000, 0B00001000, 0B00000100, 0B00000010, 0B00000001
void PCF8574Class::Prox(int addr, int pin, int x) {
 state = PCF8574.read(addr);
 if (x == 1)
 state &= pin_array[0][pin];
 else if (x == 0)
 state |= pin_array[1][pin];
 PCF8574.write(addr, state);       // ON
void PCF8574Class::Set(int addr, int bits){
   write(addr, bits);
int PCF8574Class::read(int addr) {
 Wire.requestFrom(addr, 1);
 if (Wire.available()) {
 return Wire.read();
void PCF8574Class::write(int addr, int data) {
 current_data = data;
 Wire.beginTransmission(addr);
 Wire.write(data);
 Wire.endTransmission();
The .pde >>>
Code: [Select]
#define EXPANDER_A B00100000 //0x20 //PCF8574
#define EXPANDER_B B00100001 //0x21 //PCF8574
PCF8574.Set(EXPANDER_B, 0x7F);
void loop(){
PCF8574.Prox(EXPANDER_B, 1, 1);  //this turns ON bit 1 on your secondary expander B
PCF8574.Prox(EXPANDER_B, 1, 0);  //this turns OFF bit 1 on your secondary expander B
PCF8574.Prox(EXPANDER_A, 1, 1);  //this turns ON bit 1 on your primary expander A
PCF8574.Prox(EXPANDER_A, 1, 0);  //this turns OFF bit 1 on your primary expander A
Frédéric_Plante
Yeah I got this:
http://www.ebay.ca/itm/221250141730?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Comming by post.
Tel me, is your libraries bidirectional?
Ill check on that as soon as i receive the piece. Thank fo you work.
As we fight our way northward into the great unknown, only that one thing remains certain...
robtillaart
Prox seems to write values .
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
