Author Topic: kph to mph  (Read 257 times)
Scunthorpe, UK
"to make something better we have to break it"
hi all, a little help needed.
kph / 1.609 = mph so i have seen on the internet but i don't know how i would do this in arduino. do i have to use a float?
thanks.
Germany
As you ask, the answer is "Yes".
However, to work with long, you could easily multiply by 10000L, add 5 for perfect rounding, and then divide by 16090
to get mph from a km/h value.
int mph = (int)((kph * 10000L + 5)/ 16090);
BTW: rounding assumes you work with positive values.
Scunthorpe, UK
thank you michael_x, i will give that a try and yes it's positive numbers.
thanks.
nr Bundaberg, Australia
Just work with metres instead of kilometres (ie everything 1000x larger) and format accordingly for display.
______
Rob
Scunthorpe, UK
the value am reading is kph via a cars obd and i can't change that.
Scunthorpe, UK
michael_x,
int temp;
temp = ((kph * 10000L + 5)/ 16090);
that worked fine but this also worked fine but only returned a value with no decimal. i don't want the decimal anyway.
int temp;
temp = str[0] / 1.609;
this is what i have done now and it looks to work fine.
    case VS:
    temp = (str[0] * 10000L) / 16090L;
    sprintf(PID_result, ("%d MPH"), temp);
    break;
thanks for the help.
« Last Edit: June 10, 2012, 05:45:02 am by Pavilion1984 » Logged
