Loading...
Pages: [1]   Go Down
Author Topic: Mega 2560 - FTDI possibly not working...  (Read 406 times)
Offline Offline
Newbie
View Profile
Hey Forum!
So... after getting my board out of the dust I was trying to upload a little test sketch. But after getting an error message. I tried 'lsusb' on linux which didn't show my board so I thought it might be broken... Today I tested it on a windows machine and same problem... The sketch won't upload...
Code:
avrdude: stk500v2_command(): unknown status 0xc8
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude: stk500v2_command(): unknown status 0x01
avrdude: stk500v2_disable(): failed to leave programming mode
That's the error message on windows. When I plug in my board windows won't recognize it so I installed the driver manually. Same result.
I'd really like to programm my Arduino so I'd be really pleased if I got an answer soon smiley
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
The Mega2560 didn't use a FTDI chip.  It uses an ATmega8u2 as the usb-to-serial adapter, which should appear as a usbmodem on to your operating system.
Logged
www.cmiyc.com - A guide to being an Enginerd
Offline Offline
Newbie
View Profile
Hmm.. Ok thanks smiley
But still won't recognize the device
Could it be a driver issue on both operating systems?
Or can I buy a device to replace the old chip?
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
On linux when you attach the device, you should see something logged to dmesg.  If not, the serial-to-usb converter may not be working.
Logged
Offline Offline
Newbie
View Profile
Well.. Nothing arduino or USB relevant logged to dmesg...
So what do I look for to replace the old chip?
Thanks so far smiley
Logged
Lancashire, UK
Offline Offline
Edison Member
View Profile
WWW
I'd try a different USB cable first.
Logged
Pages: [1]   Go Up
Print
Jump to:
