Topic: uno board not appearing on mac os x nor windows (Read 670 times) previous topic - next topic
newduduino
I have a new arduino UNO R2 board.
When plugged on mac os x, the green led lit and the orange one blinks (first I think to show the bootloader work and then regular pace like the blink sketch).
But it does not appear in serial port menu from arduino 1.0.1. It does not create a tty.* device in /dev/, it does not show in hardware -> USB list from System Information.app.
I then tried to flash the dfu as explained in this post :
http://arduino.cc/forum/index.php/topic,52447.msg374201.html#msg374201
Then I saw that the second wire is not necessary since in the R2 there is already a resistor.
I tried the dfu programmer but no device is found.
I tried to go through a hub (from my dell lcd) as explained here :
http://arduino.cc/forum/index.php/topic,88195.0.html
Nothing.
Then I tried to plug the board on windows XP on a thinkpad.
Nothing, no com port in System conf.
So it seems I have a new board with the mega8u2 not functioning.
What can I do ?
Is there a way to program the board through the ICSP ? How ?
Thanks for your help.
Sincerely,
newduduino
I forgot some other tests I have done.
I tried the hack from here:
http://arduino.cc/forum/index.php/topic,108936.0.html.
No numbers are added to the /dev/tty.SerialPort created (modem type).
I tried the Loopback instructions from the first post of the forum.
Nothing.
James C4S
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
newduduino
Yes !
That was one of the first thing I've done.
James C4S
Do you have an in-circuit programmer (or another functioning Arduino to use as a ISP)?  If so, you can program the 8u2 with the ICSP header next to the chip.
newduduino
I have a teensy 2.0.
Is there a tutorial for this kind of arduino programming ? That is to use another programmer, plug it to the 8u2, and configure arduino to use that programmer...
Thanks.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
