Topic: star wars blaster with arduino (Read 12384 times) previous topic - next topic
onesky
Jun 10, 2012, 09:10 pm Last Edit: Sep 26, 2016, 01:17 am by onesky
hello this is my project to add sound and light effects to a scratch built stormtrooper blaster (E-11 blastech) as seen on Star Wars "A New Hope"
the project is almost completed, this is the video that shows how it works
http://www.youtube.com/watch?v=KIUVYMPBCyQ&hd=1
i attached the code, it's not the best and rational program ever made, i am quite sure that if array variables were used, the code could have been far shorter, but i am not so expert..
talofer99
Very Cool !!
Would love to see the comlete project :)
onesky
Very Cool !!
thanks for your comment, i will post here the built weapon armed with arduino when finished :)
the-rebel-agent
Very cool indeed, and that's exactly what I had in mind for my V gun. Could you list the Arduino hardware you used and shields for sound? I see a Wave Shield right? And you said you were using a nano Arduino?
onesky
i listed all the hardware needed at this stage on the whitearmor forum, i gave you the link in other topic
in that video you can see arduino UNO, but in the final stage i will use the arduino NANO 328, same specs of the UNO but smaller
the mp3 player you see on video is quite expensive and large dimensions, today i got the WTV020, you can read here:
http://arduino.cc/forum/index.php/topic,110924.0.html
the-rebel-agent
Thanks again. I don't have access to that forum yet. About the board you bought, I bought the same board yesterday. It is SOMO-14D compatible in so many aspects. You could read about it here:
http://embeddedadventures.com/soundout_wtv020_module_mod-1007.html
It is quite expensive, but they used the same chip.
the-rebel-agent
Did not check the code yet, cause I did not installed Arduino IDE, but basically you are sensing the button, and each times some triggers it, you play the sound and turn on the led? At the same time or that is synchronous?
onesky
in my project you use 3 buttons: fire, weapon selector and reload ammuniton
when push fire button the led and sound turn on syncro
these are the features since now:
- 13 sounds weapon, included: E11, Stun, AT AT, Xwing, Xfighter, chewbacca, jawas, 44Magnum, M1 Garand, K98 and others (can add many more)
- 3 buttons: fire, selector, reload
- sound effect when empty ammo is reached
- sound effect when reloading the weapon
- sound at start-up
- plays random tracks for specific sounds (as chewbacca or jawas)
- endless fading led showing status ON / OFF
- 3 watt RGB superbright led with customizable colors and effects
- 10 segments led bar as shot counter
- 3w+3w audio output
- battery life: around 2 hours of use, standby not tested (battery used: 2x Cr123 recharg. lithium 3,7 volts)
onesky
#8
Dec 01, 2012, 12:30 pm Last Edit: Dec 13, 2012, 08:11 pm by onesky Reason: 1
the final work!
http://www.youtube.com/watch?v=N9OLZoZEpEM
the-rebel-agent
Bellissimo! Really. Congratulations! Thanks to you I met this Arduino thing, and I am really happy about it. What's the story about that RGB led. Where did you get it and how do you use it?
onesky
#10
Dec 01, 2012, 01:46 pm Last Edit: Dec 01, 2012, 01:49 pm by onesky Reason: 1
thanks!
i hope to see your vgun  video soon!
the RGB led must have 6 pins (anode and cathode) as this and it's powered by 3 constant Current Regulated LED Driver 1W 320~350mA (with minor mods) as this
Lakes
Very good, you just need to build the Stormtrooper Uniform now. :D
onesky
thanks, already did ;)
me with the arduino blaster :)
Lakes
onesky
i add this picture that shows where arduino was placed
