Topic: Send XML-File over HTTP-Request to Arduino board (Read 1 time) previous topic - next topic
I'm using the arduino board with webduino library to control some outputs over the web browser.
Now i want to send a XML-File to the board and then read the file back from it!
Any ideas for my problem?
Can't you just use POST from the library to read values? If you have to send the whole XML then, most likely you need to get it through POST and parse it manually in your code!
