Topic: [SOLVED] Trying to Randomly Move a Servo (Read 1 time) previous topic - next topic
codlink
Jun 11, 2012, 02:43 am Last Edit: Jun 11, 2012, 06:06 pm by codlink Reason: 1
Basically I am trying to "blink an eye."  The servo is connect to an eyelid and I want it to blink all the open or closed.  I have a randomized code that moves the servo to random locations.  How would I go about coding this to move it randomly from closed to open without stopping in the middle?
#include <Servo.h>
Servo myservo;
int pos = 0;
int delay1 = 0;
myservo.attach(9);
  pos=random(65,115);
delay1=random(50, 500);
myservo.write(pos);
delay(delay1);
//LiNK
WizenedEE
bool open = random(2); // open is 0 or 1 ie false or true
// Three ways to do it with varying levels of verboseness
// 1:
if (open) {
  eye.write(120);
else {
  eye.write(30);
// 2:
eye.write(open? 120 : 30);
// 3:
eye.write(90*open + 30);
codlink
I just don't know enough about writing a program to implement your code.  I guess I will have to keep studying...
//LiNK
dkl65
#include <Servo.h>
Servo myservo;
boolean state;
  myservo.attach(9);
  state = random(2);
  if (state) myservo.write(115); //open
  else myservo.write(65); //close
  delay(random(50, 500));
This will randomly either close, or open the eye, and wait a random delay. If you want the numbers to be very random, use http://code.google.com/p/tinkerit/wiki/TrueRandom.
Visit http://www.glenof.webs.com/!
codlink
Thanks dkl65
Haven't looked at boolean yet.  That is where I was stumped.
//LiNK
JimboZA
@WizEE....
I intuit that the syntax:
(open? 120 : 30)
is a test for open, and if it's true return 120, else return 30.
But I can't find the syntax anywhere in the Arduino Reference so I'm intrigued as to where you found out about it. Is it lurking in the reference somewhere that I didn't see?
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
Arrch
@WizEE....
(open? 120 : 30)
Trick from C, not specific to Arduino:
http://en.wikipedia.org/wiki/Ternary_operation
dkl65
You can also try www.cplusplus.com for C++ code reference. The Arduino reference focuses on functions in the Arduino library, rather than C/C++ itself.
