Loading...
Pages: [1]   Go Down
Author Topic: uarduno driver compilation error on FreeBSD 8.2 i386  (Read 950 times)
Offline Offline
Newbie
View Profile
Hello,
I am trying to compile uarduno driver under FreeBSD 8.2 i386, but  getting following error:
If anybody have an idea what I am doing wrong, it would be highly appreciated
Code:
# make
===>  Building for uarduno-1.02
Warning: Object directory not changed from original /usr/ports/comms/uarduno/work/uarduno
cc -O2 -pipe -DKERNELVER=801000 -fno-strict-aliasing -Werror -D_KERNEL -DKLD_MODULE -nostdinc   -I. -I@ -I@/contrib/altq -finline-limit=8000 --param inline-unit-growth=100 --param large-function-growth=1000 -fno-common  -mno-align-long-strings -mpreferred-stack-boundary=2  -mno-mmx -mno-3dnow -mno-sse -mno-sse2 -mno-sse3 -ffreestanding -fstack-protector -std=iso9899:1999 -fstack-protector -Wall -Wredundant-decls -Wnested-externs -Wstrict-prototypes  -Wmissing-prototypes -Wpointer-arith -Winline -Wcast-qual  -Wundef -Wno-pointer-sign -fformat-extensions -c uarduno.c
uarduno.c: In function 'uarduno_set_line_coding_reset':
uarduno.c:1364: error: called object '"%s: "' is not a function
uarduno.c:1391: error: 'struct ucom_softc' has no member named 'sc_dev'
uarduno.c:1391: error: called object '"%s: "' is not a function
uarduno.c: In function 'uarduno_set_line_coding':
uarduno.c:1411: error: called object '"%s: "' is not a function
uarduno.c:1417: error: called object '"%s: "' is not a function
uarduno.c:1436: error: 'struct ucom_softc' has no member named 'sc_dev'
uarduno.c:1436: error: called object '"%s: "' is not a function
uarduno.c: In function 'uarduno_set_line_state_reset':
uarduno.c:1479: error: 'struct ucom_softc' has no member named 'sc_dev'
uarduno.c:1479: error: called object '"%s: "' is not a function
uarduno.c: In function 'uarduno_set_crtscts':
uarduno.c:1526: error: 'struct ucom_softc' has no member named 'sc_dev'
uarduno.c:1526: error: called object '"%s: "' is not a function
uarduno.c: In function 'uarduno_cfg_param':
uarduno.c:1698: error: 'struct ucom_softc' has no member named 'sc_dev'
uarduno.c:1698: error: called object '"%s: "' is not a function
uarduno.c:1709: error: 'struct ucom_softc' has no member named 'sc_dev'
uarduno.c:1709: error: called object '"%s: "' is not a function
*** Error code 1
1 error
*** Error code 1
Logged
Dallas, Texas
Offline Offline
God Member
Old, decrepit curmugeon
View Profile
WWW
These may help
http://www.freebsd.org/cgi/query-pr.cgi?pr=ports/159090
http://www.freebsd.org/cgi/query-pr.cgi?pr=156876&cat=ports
Logged
New true random number generation library available at: http://code.google.com/p/avr-hardware-random-number-generation/
Current version is Entropy.v0.6.zip
Information about the library is available from: http://code.google.com/p/avr-hardware-random-number-generation/wiki/WikiAVRentropy
Pages: [1]   Go Up
Print
Jump to:
