Topic: Need Help Debugging Arduino MEGA 2560 and GPS Shield (Read 2144 times) previous topic - next topic
tmonteit
I have an Arduino mega that is connected to a CIROCOMM GPS Shield
Background:  I made this work once using example code from the internet.  However it recently stopped working and has never worked since.  I don't believe this is equipment problems because I have both a spare Mega and a spare GPS Shield.  The symptoms are the same regardless of what combination of equipment I use.   I really do not know what is going on or how to debug this system.    Can someone please help explain some techniques that will allow me to debug this?
Problem:   The problem appears to be in the Serial3 connection.  Serial3.available() never returns true.    How can I figure out what is going on here?
//////  BEGIN CODE  ///////
// WIRING:
//   1. GPS is powered and Grounded.  After about 20 seconds the GPS achieves lock.
//       GPS lock is indicted by a solid red light.
//   2. GPS TX (blue wire) is connected to Mega 14 (Tx3)
//       GPS RX (yellow wire) is connected to Mega 15 (Rx3)
#include <TinyGPS.h>
#define GPSBAUD 4800
TinyGPS gps;
void getgps(TinyGPS &gps);
  Serial3.begin(GPSBAUD);
  Serial.println("GPS TEST CODE ");
Serial.println("entering loop");
if(Serial3.available()) {   // PROBLEM IS HERE!!!  -  Never is available
    Serial.println("serial3 available");   // THIS LINE NEVER PRINTS
    Serial.println("serial3 not-available");    // THIS LINE ALWAYS PRINTS
while(Serial3.available())     // While there is data on the RX pin...
     int c = Serial3.read();    // load the data into a variable...
     if(gps.encode(c))      // if there is a new valid sentence...
       getgps(gps);         // then grab the data.
//////  END CODE  ///////
SurferTim
Without seeing a datasheet on the device you are using, I would question this:
Quote
// WIRING:
Normally the Tx on one device is connected to the Rx on the other device.
tmonteit
Correction:
Below is wiring:
// WIRING:
//   2. GPS RX (blue wire) is connected to Mega 14 (Tx3)
//       GPS TX (yellow wire) is connected to Mega 15 (Rx3)
SurferTim
#3
Jun 11, 2012, 12:07 pm Last Edit: Jun 11, 2012, 12:12 pm by SurferTim Reason: 1
If the wiring is correct, then I would check the GPS Tx line with my o-scope for timing and voltage levels.
add: I would change the code temporarily to just read the GPS output and send it directly to the serial monitor.
Code: [Select]
     Serial.write(c);
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
