Topic: simplemessagesystem example1 not compiling (Read 797 times) previous topic - next topic
lofidisaster
Hi all, this is a newbie question:
I'm trying to comunicate an Arduino Uno with max/msp, and i can't compile de sketch onto the arduino, i'm using arduino 1.0
it says:
SimpleMessageSystem_example_1.cpp: In function 'void loop()':
SimpleMessageSystem_example_1.pde:-1: error: 'messageBuild' was not declared in this scope
SimpleMessageSystem_example_1.pde:-1: error: 'messageGetChar' was not declared in this scope
SimpleMessageSystem_example_1.cpp: In function 'void readpins()':
SimpleMessageSystem_example_1.pde:-1: error: 'messageSendChar' was not declared in this scope
SimpleMessageSystem_example_1.pde:-1: error: 'messageSendInt' was not declared in this scope
SimpleMessageSystem_example_1.pde:-1: error: 'messageEnd' was not declared in this scope
SimpleMessageSystem_example_1.cpp: In function 'void writepin()':
SimpleMessageSystem_example_1.pde:-1: error: 'messageGetInt' was not declared in this scope
any ideas of what's happening?
I got the simplemessagesystem library in libraries, and the sketch shows up in the examples tab.
Thanks in advance to anyone that can help!
johnwasser
At the top of this page: http://arduino.cc/playground/Code/SimpleMessageSystem
it says "USE THIS INSTEAD:" http://arduino.cc/playground/Code/Messenger
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
lofidisaster
Thanks for your answer!
Yep, and then use cmd messenger instead!
It doesn't compile as well... soi found an max patch example that looked allright with sms so i gave it a try.
But you're right, now back to cmdmessenger...
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
