Topic: Random (Read 1 time) previous topic - next topic
jmnijsse
I try to turn on max 5 leds by pressing 2 buttons.
For this I used this script below.
But, after reset, the most time the same led is beaming.
Is there any improvement on it?
Gr.
Johan
int led[] = {3,4,5,6,7,8};
int numberLeds = 6;
int button1 = 9;
int button2 = 10;
  for (i=0;i<5;i++){
    pinMode(led[i],OUTPUT);
    digitalWrite(led[i],LOW);
  pinMode(button1,INPUT);
  pinMode(button2,INPUT);
  randomSeed(analogRead(0));
  if (digitalRead(button1)&&digitalRead(button2)){
    if(random(100)>50){
      digitalWrite(led[random(numberLeds)],HIGH);
    if(random(100)>50){
    if(random(100)>50){
    if(random(100)>50){
    if(random(100)>50){
    while(true){
AWOL
You random seed should be in "setup"
Coding Badly
Why analogRead is a bad choice...
http://arduino.cc/forum/index.php/topic,66206.msg630884.html#msg630884
The reliable but not very sexy way to seed random...
http://arduino.cc/forum/index.php/topic,66206.msg537783.html#msg537783
And, of course, heed AWOL's advice.
michael_x
#3
Jun 13, 2012, 10:23 am Last Edit: Jun 13, 2012, 11:54 am by michael_x Reason: 1
As there's manual input ( button push ), you could use millis() of the first button press as a random seed, too.
Or simply call random(); in the beginning of loop() where now is your randomSeed(), this will be repeated an undefinite number of times, until both buttons are pressed.
BTW: Your code does not generate a sequence at all, as it never ends the loop().
Strange design... you need to press 3 buttons: Reset, then the 2 others together.
Edit: sent too early
jmnijsse
Thanks all.
It's working for the purpose we want.
And yes, it's a strange design, but we have no time to make it better.
(pupils always start to late with their projects...)
Gr.
Johan
PaulS
    while(true){
That looks plain stupid. If you want the Arduino to stop doing anything useful,
    while(true)
It makes no difference whether it executes the while loop several million times per second, or wastes time in the delay() function.
RandallR
Personally I use
while(1);
It is short, simple and easy to type.  The danger is it could it lost in the code and cause it to "Hang".
Coding Badly
exit( 1 );
...is a good choice.  Stops execution.  Easy to spot.  No ambiguity regarding its purpose.
http://www.nongnu.org/avr-libc/user-manual/group__avr__stdlib.html#ga137096a48cc0c731052cadfb69c39b34
RandallR
exit( 1 );
Would this still allow you to continue to service interrupts?
I assume the Watch Dog would still restart, even after an exit.
Coding Badly
No.  exit disables interrupts.
If the watchdog is configured to generate an interrupt the interrupt is ignored.  If the watchdog is configured to reset the processor then, when it expires, the processor is reset.
nickgammon
Yes, that's a trap. Compare:
Serial.println ("Goodbye!");
while (true) ;
to:
exit (1);
One prints "Goodbye!", one doesn't.
More info:
