Topic: Good source of random numbers? (Read 9345 times) previous topic - next topic
xolroc
- http://www.random.org/integers/ - ?
I'm afraid I don't have an ethernet shield, so that's not an option!
AWOL
If finding enough entropy is the only problem, I'm willing to offer my son's bedroom as a useful source.
Graynomad
my son's bedroom
Now there's a source we haven't considered before. Probably the only one left I think.
Note that the Due should finally lay this to rest as the SAM3X has TRNG hardware.
______
Rob
wanderson
Any one who considers arithmetical methods of producing random digits is, of course, in a state of sin - John von Neumann
If you really want better randomness, you pretty much have to get it from some external physical source.
It really depends upon what you are using the 'randomness' for.  For instance simulation techniques do not usually need true randomness--only something that is close.  Something mathematical techniques are usually well suited for.  And there are a few mathematical generators that outperform all but the best of the physical sources.
Most true sources of entropy; radioactive DECAY; avalanche noise; Johnson noise; clock jiggered; all require deterministic whitening techniques in order to produce unbiased random numbers. And they are very temperamental.  Small changes to their operating environment can severely compromise their performance.
Leon Heller
ID Quantique makes the Quantis RNG:
http://www.idquantique.com/true-random-number-generator/products-overview.html
which looks pretty good. The USB-4M module costs 990 €.
Leon Heller
G1HSM
xolroc
990 €.
I'm nowhere NEAR that desperate.  I don't need it to stand up to an army of statisticians, I just need something more random than what the Arduino can do on its own!  I think the entropy library will work fine.
Leon Heller
Exploiting quantum mechanics like that is a clever idea, though.
Leon Heller
G1HSM
AWOL
But think of all the poor cats.
xolroc
Couldn't you use a tunnel diode to achieve about the same thing?  Of course, they're more expensive than Zeners....
Leon Heller
Tunnel diodes aren't suitable as noise generators.
Leon Heller
G1HSM
dkl65
I just skimmed through the thread, so I don't know if someone mentioned this already. How about trying http://code.google.com/p/tinkerit/wiki/TrueRandom. They claim that it is very random. It uses analog input A0, and some other stuff.
wanderson
They claim it is random; however, it fails even the simple tests
Entropy = 6.440816 bits per byte.
Optimum compression would reduce the size
of this 1,002,424 byte file by 19.49%
Chi square distribution for 1,002,424 samples is 4802982.71, and randomly
would exceed this value 0.00% percent of the time.
Arithetic mean value of data bytes is 100.3535 (127.5 = random)
Serial correlation coefficient is 0.042774 (totally uncorrelated = 0.0).
xolroc
I'm intrigued as to where you got those test results from... whatever you used for it seems like it would be very useful!
Coding Badly
ent can be downloaded here...
http://www.fourmilab.ch/random/
Just feed it a file of binary data.  Try a few JPGs.
wanderson
As CodingBadly mentioned ent is the source of the test results I posted; however, I made a python script that performed those tests with a few options along with some graphs which I find useful; histogram and scatter.
That python script can be found here; http://code.google.com/p/avr-hardware-random-number-generation/source/browse/analyze.py
