Topic: Unable to program brand new '328P chips (Read 10176 times) previous topic - next topic
majenko
Jun 16, 2012, 02:42 pm Last Edit: Jun 16, 2012, 02:55 pm by majenko Reason: 1
Just taken delivery of two ATMEGA328P-PU chips, and I'm trying to program them.
Code: [Select]
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
Using ArduinoISP, host board is an UNO.  Programming via home made ISP shield.
I know the shield / code / programmer etc works fine, as I can burn the bootloader to a '328P-PU lifted from another UNO board.  Have Atmel changed the device IDs in brand new '328P chips or something?
The non-working chips are both from batch code 1218.
majenko
#1
Jun 16, 2012, 02:55 pm Last Edit: Jun 16, 2012, 02:58 pm by majenko Reason: 1
More digging:
Good chip:
Code: [Select]
avrdude -pm328p -C ~/arduino-1.0.1/hardware/tools/avrdude.conf -c avrisp -P /dev/ttyACM0 -b 19200
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.06s
avrdude: Device signature = 0x1e950f
avrdude: safemode: Fuses OK
avrdude done.  Thank you.
Bad chip:
Code: [Select]
avrdude: Device signature = 0x000000
         this check.
Are these chips toast?  Is there anything more I can do to test them?
Krodal
Your 'bad' chips might have the wrong fuses.
In some cases you must use high-voltage programming to reach the chip again.
Or a fuse for an invalid clock options is selected.
To test a chip you could do this:
avrdude -p m328p -c avrisp -P /dev/ttyACM0 -vvv
majenko
Code: [Select]
avrdude: Version 5.11, compiled on Sep  7 2011 at 19:34:16
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/home/matt/arduino-1.0.1/hardware/tools/avrdude.conf"
         User configuration file is "/home/matt/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyACM0
         Using Programmer              : avrisp
         Overriding Baud Rate          : 19200
         AVR Part                      : ATMEGA328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel AVR ISP
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
         this check.
I'm not sure exactly what I am seeing there, but it looks to me like all the fuses are being read as 0x00.  If that is right, then all the options are on, including SPI program downloading.
Krodal
Your programmer seems okay (you knew that already).
But you don't have any communication with the 'bad' chip (you knew that also).
You don't know what the fuses are, since there is no communication.
You probably have a 'bricked' chip.
Unbricking is done by either supplying a clock signal to the clock input, or with high-voltage programming.
majenko
Well, these chips are brand new - arrived in the post this morning from Farnell.  I am tempted to send them back for a replacement, but I don't want to do that if the next ones are the same.
I don't have a high voltage programmer, but a clock is possible - tell me more.  I have a 16MHz crystal on the board already (my ISP shield also has an ADM232 chip and DB9 for sketch uploading), which I know works as I have uploaded the good ol' blinky sketch to a known good chip on this board, but if I need to generate an external clock then I can do that.  What frequency? What pin? Does it need to be synchronous with the programming communication?
Krodal
If they are new, they can not be bricked.
The ATmega328P-PU is the most common AVR chip there is. It will also work with lower voltages.
I have a oscillator of a few megaherz for this.
Or you could make a program, that just toggles a pin.
And use that signal for a clock for the 'bad' chip.
The datasheet says: "PB6 can be used as input to the inverting Oscillator amplifier and input to the internal clock operating circuit."
So you can feed the clock signal to PB6.
But then again: if they are new, they can not be bricked.
Is it possible that you programmed then, by placing it in your programmer ?
Can you try another programmer? or other USB-bus, or other version of avrdude ?
For now, it's a complete mystery for me.
majenko
The only way that they can have been programmed is if avrdude programmed them regardless of the mismatch of the device id.
The avrdude version I am running is the one bundled with the 1.0.1 IDE.
Krodal
Quote
Not possible. Avrdude has enough checks.
Quote
That's good, I can't find that there is a problem with it.
Mystery continues...
Jack Christensen
Stupid question, but I'll ask anyway. You're absolutely sure they are the correct chip? 328P-PU and not plain 328-PUs or something else? I usually have to put them under a magnifier. But you read the date code, so you probably also verified the part number  :~
Exceedingly small chance that a new chip would be bricked, let alone two of them.
Your second post has me baffled. I assume that the only change between the "Good chip" part and the "Bad chip" part is that one chip has been exchanged for another?
majenko
Yep, verified the part number.  I decided upon the p version instead of the non-p after a discussion in here.  I have exceedingly good eyesight.
Quote
I know, that's why I'm so confused and not just RMA'ing them straight away.
Quote
Yep.  Remove ISP shield, remove bad chip, insert good chip, re-attach ISP shield, run avrdude command.  I wish I had a high-voltage programmer, then I could really test them.  If I were to invest in one, what would be my best bet?  I don't have lots of cash, so cheap, but I want it to work.  It would have to work in Linux too, so avrdude compatible would be best.
nickgammon
You could test the signatures with my sketch described here:
http://www.gammon.com.au/forum/?id=11633
You just need to hook up a couple of wires (Gnd, +5V), add a couple of decoupling capacitors, and run the SPI wires as shown.
The chip might need a clock source, but I describe how supply one, using another Arduino, here:
http://www.gammon.com.au/forum/?id=11637
I think the default for new chips is to run from the internal oscillator, but perhaps at 1 MHz and not 8 MHz.
You could try adding -B250 to the AVRdude command line to slow down communications.
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
Jack Christensen
Ahhh, so I figured. My eyes aren't nearly long enough any more :D
Don't know much about HV programmers, but did stumble across this recently, might be worth having a look:
http://mightyohm.com/blog/products/
I'd like to try one of those chips, too bad you're not closer.
majenko
Hmmm... That has schematics.  I might have a go at making one of those - seems simple enough.
tim7
Fresh ATmega328P chips have their fuses set to run the CPU at 1MHz, using the internal on-chip oscillator.  And the SPI interface used for serial programming needs the SCK frequency to be less than  F-CPU/4 = 250kHz.
I'm not sure ArduinoISP takes any notice of the avrdude -B flag, but it it runs the SPI clock at 16MHz/128 = 125kHz so that ought to be ok...
