Topic: Placement of resistors. (Read 3896 times) previous topic - next topic
majenko
There are calculations you can do revolving around the Rdson of the mosfets in the chip, but 10K is usually "good enough" to work reliably.
Grumpy_Mike
foxbat
I've tried the solder drag method before.  I ended up with all the pins connected to eachother.  I stopped there.  Was I supposed to wick away the excess after that?
It depends a lot on the type of flux. I have just about every type you can get; no-clean liquid, rma223 and others. All will leave bridges except this dark brown gunge I've got that burns really easily. It's ability to completely destroy the surface tension of solder is uncanny and not once has it caused a bridge even on 0.4mm pitch parts.
It will even eliminate other bridges if I paste a bit on the bridge and touch it with the iron. I'd like to know what it is, maybe it's plumbers fluxite or something like that.
Osgeld
Ruby Flux brand has that ability as well, its meant for terminals and turns solder into a super flowing material. Never used it on SMD stuff but I use it all the time to tin wire. just a little bit along the length, and wipe a blob of solder and it perfectly tins ribbon cable into breadboard jumper with no lumps or missed spots.
leaves a nice red mess when I have used it on boards, though its easy to clean.
