Pages: 1 [2]   Go Down
Author Topic: Leonardo with the TLC5940  (Read 2707 times)
Is "Love" a strong word for what I feel? Thanks so much.
The new pin definitions worked perfectly.
Happy days!
Wisconsin
I LOVE THIS STUFF!!!!
Of course its not.
I...(brings up courage) love it too
Accelerate to 88 miles per hour.
Oooh guys, you make me cry smiley
However, admittedly I do not fully understand which pin/part of the leonardo to connect exactly to which pin of TLC. Could someone be so kind to clearify this? Maybe in the form as it is done explained in the BasicUse example of the TLC library?
Thanks a lot already!!
Nvermind. I have figured it out myself.
The only thing I do not understand so far is what you do with the Rx Led pin...
Wisconsin
Okay so I noticed last night while building a circuitboard that the TLC5940 Grayscale clock (for the PWM function) is connected to the INT1 pin when set-up with an ATmega328p.  When connecting it up like that on the 32U4, I noticeced the INT1 pin is also the SDA pin (for I2C/TWI).  Unfortunatly my project requires the I2C bus for a different IC.
Can I change the grayscale pin for this to another pin and will still work?
Hi funkyguy4000
This fix works succesfully with my Leonardo. In my project, this library controls the TLCs using ICSP (center wires) and the 5, 9, 10 pins on Leonardo board. Moreover, i'm sending data to an Colorduino through I2C using SDA and SCL pins.
They works perfectly without change any pin map on this fix!
Wisconsin
No changes at all? Its just if you put them on the right pins, it works?
Wow.  I haven't gotten a chance to try this, I've been too busy with my studies.
Hi -
This code was really helpful to me, but in fact it isn't the only fix you need for the Leonardo to work with the TLC 5940.  I tried running a servo motor off of it, but the pulse width was wrong.  As it turns out there are some issues with the Timers used in Leonardo that are only half-addressed in the servo header file (as the GSCLK is running about 16 times too fast), but if you look at the Tlc5940.cpp file than you can figure it out.
This is the code that your tlc_servos.h file should look like if you want to run servos off of the TLC5940 with your Leonardo.
Cheers,
Erin
/*  Copyright (c) 2009 by Alex Leone <acleone ~AT~ gmail.com>
    This file is part of the Arduino TLC5940 Library.
    The Arduino TLC5940 Library is free software: you can redistribute it
    and/or modify it under the terms of the GNU General Public License as
    published by the Free Software Foundation, either version 3 of the
    License, or (at your option) any later version.
    The Arduino TLC5940 Library is distributed in the hope that it will be
    useful, but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    GNU General Public License for more details.
    You should have received a copy of the GNU General Public License
    along with The Arduino TLC5940 Library.  If not, see
    <http://www.gnu.org/licenses/>. */
#ifndef TLC_SERVOS_H
#define TLC_SERVOS_H
/** \file
    TLC servo functions. */
#include <avr/io.h>
#include "Tlc5940.h"
#ifndef SERVO_MAX_ANGLE
/** The maximum angle of the servo. */
#define SERVO_MAX_ANGLE     180
#endif
#ifndef SERVO_MIN_WIDTH
/** The 1ms pulse width for zero degrees (0 - 4095). Default 204 */
#define SERVO_MIN_WIDTH     204
#endif
#ifndef SERVO_MAX_WIDTH
/** The 2ms pulse width for 180 degrees (0 - 4095). Default 410*/
#define SERVO_MAX_WIDTH     410
#endif
#ifndef SERVO_TIMER1_TOP
/** The top value for XLAT and BLANK pulses.  This is with the div8 prescale,
    so
    \f$\displaystyle f_{PWM} = \frac{f_{osc}}{2 * 8 * SERVO\_TIMER1\_TOP} \f$
    The default is 20000, which corresponds to 50Hz. */
#define SERVO_TIMER1_TOP    20000
#endif
#ifndef SERVO_TIMER2_TOP
/** The top value for GSCLK pulses.  Related to SERVO_TIMER1_TOP by
    \f$\displaystyle SERVO\_TIMER2\_TOP =
        \frac{2 * 8 * SERVO\_TIMER1\_TOP}{4096} - 1 \f$
    The default is 77. */
#define SERVO_TIMER2_TOP    77
#endif
void tlc_initServos(uint8_t initAngle = 0);
void tlc_setServo(TLC_CHANNEL_TYPE channel, uint8_t angle);
uint8_t tlc_getServo(TLC_CHANNEL_TYPE channel);
uint16_t tlc_angleToVal(uint8_t angle);
uint8_t tlc_valToAngle(uint16_t value);
/** \addtogroup ExtendedFunctions
    \code #include "tlc_servos.h" \endcode
    - void tlc_initServos(uint8_t initAngle = 0) - initializes the tlc for
            servos.
    - void tlc_setServo(TLC_CHANNEL_TYPE channel, uint8_t angle) - sets a
            servo to an angle
    - uint8_t tlc_getServo(TLC_CHANNEL_TYPE channel) - gets the currently set
            servo angle */
/** Initializes the tlc.
    \param initAngle the initial angle to set all servos to
            (0 - SERVO_MAX_ANGLE). */
void tlc_initServos(uint8_t initAngle)
    Tlc.init(tlc_angleToVal(initAngle));
    TCCR1B &= ~(_BV(CS12) | _BV(CS11) | _BV(CS10)); // stop timer1
    ICR1 = SERVO_TIMER1_TOP;
    TCNT1 = 0;
#ifdef TLC_ATMEGA_8_H
    uint8_t oldTCCR2 = TCCR2;
    TCCR2 = 0;
    TCNT2 = 0;
    OCR2 = SERVO_TIMER2_TOP / 2;
    TCCR2 = oldTCCR2;
#elif defined(TLC_TIMER3_GSCLK)
uint8_t oldTCCR3B = TCCR3B;
TCCR3B = 0;
    TCNT3 = 0;
    ICR3 = SERVO_TIMER2_TOP;
    TCCR3B = oldTCCR3B;
#else
    uint8_t oldTCCR2B = TCCR2B;
    TCCR2B = 0;
    TCNT2 = 0;
    OCR2A = SERVO_TIMER2_TOP;
    TCCR2B = oldTCCR2B;
#endif
    TCCR1B |= _BV(CS11); // start timer1 with div 8 prescale
/** Sets a servo on channel to angle.
    \param channel which channel to set
    \param angle (0 - SERVO_MAX_ANGLE) */
    Tlc.set(channel, tlc_angleToVal(angle));
/** Gets the current angle that channel is set to.
    \param channel which channel to get */
    return tlc_valToAngle(Tlc.get(channel));
/** Converts and angle (0 - SERVO_MAX_ANGLE) to the inverted tlc channel value
    (4095 - 0). */
    return 4095 - SERVO_MIN_WIDTH - (
            ((uint16_t)(angle) * (uint16_t)(SERVO_MAX_WIDTH - SERVO_MIN_WIDTH))
            / SERVO_MAX_ANGLE);
/** Converts an inverted tlc channel value (4095 - 0) into an angle (0 -
    return SERVO_MAX_ANGLE * (4095 - SERVO_MIN_WIDTH - value)
            / (SERVO_MAX_WIDTH - SERVO_MIN_WIDTH);
#endif
Moderator edit: [code] [/code] tags added.
« Last Edit: April 04, 2013, 01:08:24 pm by Coding Badly » Logged
Pages: 1 [2]   Go Up
