Pages: [1] 2   Go Down
Author Topic: Stack overflow  (Read 787 times)
Dubai, UAE
How is a stack overflow visible in a project ? Does it reset the Arduino or is there a specific interrupt that gets triggered or do you just find out through unexpected behavior ?
Thanks
Duane B
rcarduino.blogspot.com
Manchester (England England)
Solder is electric glue
That's the one.
Dubai, UAE
Thanks,
I have just made a few changes that should be good for 30 or 40 bytes, I am running on an 1K ATMega8 and the project is behaving as if a global variable is being overwritten with zero after a period.
Duane.
UK
Online Online
You mean some sort of mechanism that pushes the machine's current state and registers onto the stack?   smiley-wink
Dubai, UAE
Now that you mention it - smiley-red
Australia
You might be able to see it occur if you run the hex file in a simulator like AVR Studio 4, I show it happening here:
Melbourne, Australia
Shannon Member
Lua rocks!
Very amusing. smiley
The stack that is no more?
UK
What a host of balls she had seen: gaity, the brass buttons...
Some more advanced microcontrollers do have a system for handling this.  It's just like an interrupt, but it's called an "exception".   They are more critical than interrupts, and you aren't always expected to be able to return from it.  They are usually linked to such events as "address error", or "divide by 0" and other such critical events.
Not something the low-end Atmel chips do I'm afraid.
UK
Online Online
My favourite was the 68000 double bus error.
A single bus error caused the processor to jump via a vector when an area of memory that wasn't mapped was accessed.
A double bus error occurred when the bus error vector pointed to a region of memory that wasn't mapped!
Shannon Member
Lua rocks!
The Blue Screen Of Death.
Oh, wait. There isn't a screen.
UK
I'm sure my guru meditated on that problem many a time smiley
Dubai, UAE
Just out of interest - I am not near an AVR now, what does it do for divide by zero ?
Duane B
UK
Online Online
Divide by zero?
Nothing at all.
Carries on, regardless.
Austin, TX
CMiYC
unsigned int numerator = 47;
unsigned int denominator = 0;
unsigned int result = numerator / denominator;
Serial.print("Int: ");
Serial.println(result);
float floatNumerator = 47.0;
float floatDenominator = 0.0;
float floatResult = floatNumerator / floatDenominator;
Serial.print("Float: ");
Serial.println(floatResult);
Resulted in:
Int: 65535
Float: 0.00
www.cmiyc.com - A guide to being an Enginerd
Divide by zero is a concept that we have, to the computer it is just another operation. Sometimes we build the "this is a bad thing" concept into the processor, other times into the software, but the processor dosn't cair.
Pages: [1] 2   Go Up
