Pages: [1] 2   Go Down
Author Topic: BMS- battery management system arduino based  (Read 1106 times)
Hi there..
i'm here with small doubt i want to build a a small device that measures the voltage of my battery bank
i have 6 2v cells connected in series to give ~12v  (~because they can go from 1,75v to 2,45v) and thi is exactly what i want to know.
So with that the voltage i won't need any voltage divider, but my first ideia (stupid one)  was this:
but with this layout i would be adding the cells voltage and at the last one i would have 12v on arduino pin, right ?
so how do i connect all this to arduino so i can read each cell individually ?
regards
a, b = b, a+b
How about you do some simple math?
subtracting the reading at A4 from the reading at A5 should give you the voltage of battery 6, right?
Brunsbüttel, SH, F.Rep.GERM
ideas:
1. voltage divider in hardware (decreases accuracy) and undoing that division with a program and building differences in software...
2. one attiny per cell (powered by that cell), that talks to the arduino via 2 opto-coupler or some mosfets (with a smaller voltage divider that brings the voltage below Vref=1.1V)
3. 1 mechanical relay per connection (1 for the lowest minus-pole and 1 for each plus pole = 7 relay) that r connected to the arduino, so that the cell to be measured is connected to arduino ground and arduino analog pin
4. idea 3 with each relay substituted by 2 mosfets (p-mosfets should be fine for the plus-pole-relay and n-mosfets for the lowest-minus-pole-relay)...
and warning:
on ur picture it looks like a phat short circuit... dont do that at home...  smiley-wink
« Last Edit: June 18, 2012, 01:45:54 am by RIDDICK » Logged
-Arne
Hi
@fkeel
that was a way but i would need voltage dividers after the first cell and i would loose accuracy, but so far its the only way i know how to do it..
@Riddick
Your idea 3 confuse-me i can't understand correctly  can you please make drawing or something..
Regards.
a, b = b, a+b
For simplicity I would use a voltage divider for each channel (set to the same voltage ratio). Your accuracy should not be significantly influenced by that.
p.
nr Bundaberg, Australia
After the second cell, but that's not important right now.
What accuracy do you need?
______
Rob
oki - here comes the picture:  smiley
http://www0.wgboome.org/idea3.png(i mixed idea #3 and #4)
(the minus pole of B1 must not be connected to arduino's ground)
-Arne
Link no work smiley-sad
______
Rob
*sob* why? what does it say? did u type the "0" after the www?   smiley-eek-blue
-Arne
I just clicked on the link, then thinking it was a typo tried without the 0, then tried clicking the link again.
But now it works, go figure.
______
Rob
I think I get what you are doing there.
It's very prone to a magic smoke event if you get the sequence wrong though.
I would be inclined to control the relays with a decoder so there's no chance of the wrong relays being energised at the same time.
______
Rob
a, b = b, a+b
"magic smoke event" added to vocabulary.
u can connect the arduino via a 5kOhm resistor and (further) protection diods pointing from ground to the arduino pin and from the arduino pin to +5V...
-Arne
a, b = b, a+b
seems like an awful lot of hassle, when you could just use voltage dividers...
yes, indeed... but it is a possibility...  especially if u use a long battery chain...  smiley-wink
-Arne
Pages: [1] 2   Go Up
