Topic: uno as ISP bootloader for a ATmega162 (Read 2624 times) previous topic - next topic
evostars
Jun 18, 2012, 01:35 am Last Edit: Jun 18, 2012, 01:36 am by evostars Reason: 1
Hi
I've got a ATmega162(from my x0xb0x) without a bootloader.
Can I use the Uno as a ISP to put the bootloader on the 162?
I've got the bootloader hex file but I dont know how to put it on.
Could anybody please help me out?
Coding Badly
Let's find out.  First stop, the datasheet... http://www.atmel.com/Images/doc2513.pdf  We need to look through the Memory Programming section.  We're looking for Serial Downloading.  And, it's there.
Wiring is easy to remember...
MISO to MISO
MOSI to MOSI
SCK to SCK
GND to GND
SS on the Uno to RESET on the target
The target has to be powered close to 5V.  As long as the current is within reasonable limits, the target can be powered from the Uno.
The target's SPI pins are listed in the Memory Programming / Serial Downloading section.
Tom Carpenter
From when i did it,
SCLK = Pin8
MISO = Pin7
MOSI = Pin6
RESET = Pin9
VCC = Pin40
GND = Pin20
XTAL1 = Pin19
XTAL2 = Pin18
I used an uno to upload it as suggested above.
~Tom~
evostars
yes I got that far. Got the pins right.
But in the IDE, I dont get to bootload my own .hex file.
Instead I see I can only select different cpu's. I even tried selecting a 168, but when I bootload, it says error wrong cpu (or something like that).
I dont see how I can load my own bootloader.hex file into my 162 chip, with the IDE...
I've read and used these:
http://arduino.cc/en/Tutorial/ArduinoISP
http://arduino.cc/en/Tutorial/ArduinoToBreadboard
But they dont explain how to do it with a other cpu (162)
should I maybe copy paste the bootloader.hex file of the atmega162 to the right map (exeamples?)?
evostars
after reading this: http://www.atmel.com/Images/doc2513.pdf  We need to look through the Memory Programming section.  We're looking for Serial Downloading.
I learned I ned to pull down reset to ground, to program it, I had it tied down to 5V.
But still no clue how to proceed...
Tom Carpenter
Have you edited the boards.txt file to include the Atmega162?
If so, select that as the current board (tools->board), and then select the programmer (tools->programmer-"Arduino as ISP"). Then click burn bootloader (tools->"burn bootloader")
That will locate the hex file specified in the boards.txt file, and burn it to the Atmega162.
Quick question, are you using the bootloader I modified? If so, I realised there is a mistake in the pins_arduino.h file which I will change in my other thread. If you did use mine, you will need to redownload the .h file.
~Tom~
evostars
No, i didn't use your bootloader. Got a link for me?
I'll try to find the textfile, and change it.
Thanks!
Tom Carpenter
There is another thread called "Making Bootloader for Atmega162", just below this one.
~Tom~
evostars
Ah cool. Missed that.
