It actually appears to have nothing to do with the code, rather just with the size of the code. Smaller programs upload fine, larger ones and ones about the same size do not. I'll include the code below, and the errors as an attachment (verbose output on).
Edit: also, the loopback test reveals that there is nothing wrong with the USB interface.
I find it hilarious that it repeatedly sends "Bootloader>Huh?" and I think that there might be a problem with the bootloader, which is odd because it works fine with smaller sketches.
/* Example playing a sinewave at a set frequency,
* using Mozzi sonification library.
* Demonstrates the use of Oscil to play a wavetable.
* Circuit: Audio output on digital pin 9.
* Tim Barrass 2012.
* This example code is in the public domain.
#include <MozziGuts.h>
#include <Oscil.h> // oscillator template
#include <tables/sin8192_int8.h> // sine table for oscillator
// use: Oscil <table_size, update_rate> oscilName (wavetable)
Oscil <SIN8192_NUM_CELLS, AUDIO_RATE> aSin(SIN8192_DATA);
// use #define for CONTROL_RATE, not a constant
#define CONTROL_RATE 64 // powers of 2 please
void setup(){
startMozzi(CONTROL_RATE); // set a control rate of 64 (powers of 2 please)
aSin.setFreq(440u); // set the frequency with an unsigned int or a float
void updateControl(){
// put changing controls in here
int updateAudio(){
return aSin.next(); // return an int signal centred around 0
void loop(){
audioHook(); // required here
